I wanna buy a fuel pressure gauge LT1
Old Dec 28, 2004 | 03:52 PM
EliteZ's Avatar
Precision Motorsports
Default LT1 Fuel Pressure Gauge Info
What kind do I need to buy? Electical right(or Mechanical). how do I connect it to the lt1? I wanted to buy the Autometer Phantom to match my tach
448WHP/420WTQ
Full bolt-ons+H/C
Car Sound Clip & More(W/ Mekanic)
Tuned by Precision Motorsports
Old Dec 28, 2004 | 04:46 PM
formula69's Avatar
blowed up
theres a few differences...
the electrical gauge uses an electric sender unit to send fuel pressure measure to the gauge... this basically means you can mount the gauge inside the car because there wont be any fuel lines past the firewall... i know that an autometer sport-comp electrical fuel pressure gauge is $190
mechanical fuel pressure gauges must be mounted outside of the vehical.. e.g. mounted in a cup on the hood.. this is significantly cheaper... probably under 100 for the gauge..
now you will need to find the bleeder valve behind the intake manifold. you will need to connect -4an line to this bleeder valve and connect the other end of the line to the gauge.
Originally Posted by 05general lee
im FAT!!!!
Originally Posted by Little Nicky
Scott is my body guard
T.R. $100,000 kill club member #002
Turtle crew member #2
Old Dec 28, 2004 | 07:49 PM
EliteZ's Avatar
where can I get the line from I know where the bleeder valve is on the fuel rail--Schrader valve? I can use that one right
448WHP/420WTQ
Full bolt-ons+H/C
Old Dec 29, 2004 | 06:05 AM
Sneakin Deacon's Avatar
PSSHHH x2
yes you can use that...also if you want the gauge in-car but keep it cheap with a mechanical, they sell a little dohickey called in isolator that you can hook up, that way its only water running into the cabin and not fuel. for ease of install and mind, id go with an electronic one. no chance of lines getting knicked and stuff.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
