pontiac grand prix motor swap
Old Dec 20, 2004 | 08:52 PM
hondasux's Avatar
Default pontiac grand prix motor swap
how hard is it to swap over a gtp motor into a regular v6 grand prix???
same mounting places??
is it as easy as switching over the wiring harness??
"what comes around goes around."
I love karma and as the days go by i see more and more people getting bit in the ass.
Old Dec 26, 2004 | 03:42 PM
Soluxx's Avatar
If its the same model type, then it should be virtually a no-brainer. The only real difference between the two (if they're the same type) is the supercharger and internals (I think).
Old Dec 27, 2004 | 11:18 AM
myltwon's Avatar
Bolt-On 2v GT
prolly only differences are different compression and of course the s/c
Old Jan 1, 2005 | 04:30 AM
sebastian's Avatar
are the tranny's the same though? Wouldn't it matter hooking a super charged motor up to the regulkar v6. I know it sounds like one dumb ass question but thats what one mechanic tried telling me. Need and gtp parts though?
Old Jan 3, 2005 | 04:51 AM
Soluxx's Avatar
The trannys are the same, though the GTP has a 'quick shift' button on it. Basically its an electronic shift kit because the tranny will slip under very hard acceleration if its not on. I imagine the supercharger is the main contributor to this.
Old Jan 8, 2005 | 11:23 AM
shutdown99's Avatar
The trannys are different. The GTP comes with a HD or heavy duty tranny. The blocks are the same but the heads and intake are different.
you will needs a wire harness and a gtp computer.
The GTP also comes with a bigger radator.
Now your stock tranny (assuming you have the 3.8L not the 3.1)will bolt up but it will NOT last. Even the GTP tranies dont last long if you go over 300 HP.
For some rason the people who put turbos or Cintrifical (SP?) SuperChargers on a l36 motor have better luck with the trannys than those who do the swap. Plus the l36 trans has a higher gear ratio which is better for the track.
Another note: The M90 isn't effeciaent at all. check out zzperformance.com or intense-racing.com for a Turbo kit or CSC kit. also might want to look at L67swap.com
If i was going to start over, id toss the M90! hope this helps.
Good luck!
Old Jan 15, 2005 | 07:56 AM
thatonedude1's Avatar
Default Re: pontiac grand prix motor swap
if the old engine is good let me knoe, i am gunna try nd get a grnd am and i want to go to the v6 3.1l engine, even cooler if it was the 3800
I was young dumb and full of cum.
