simple rwhp tricks for 4.3L's?
Old Dec 13, 2004 | 04:31 PM
Jakethesnake's Avatar
Bombs over Baghdad...
Originally posted by phinger23
ok LT1 swap
why dont I just swap a zz4 motor in there for my d/d? thanks for all the big help everyone!
Proud OIF/OEF Veteran and still serving
Old Dec 13, 2004 | 05:42 PM
gator's Avatar
Underdog
put a bigger gear in it. 4.10s are pretty sweet and were OEM on a few years models. not like it gets great milage anyways. i had them in my ole s15 GMC Jimmy. otherwise it is a low performance engine. i doubt opening the catback is worth it.
probably at its milage, new fuel filter, new air filter, and plugs/wires will help out the most.
1999 Pontiac Trans Am
Originally Posted by 1Bad00SS
What makes you think you could of keep up with me. Have you ever had that car on a dyno?
Old Dec 15, 2004 | 02:33 PM
hmm so looks like I will add a cold air or filter or w/e and prob call it a day!! thanks Fordified thats the answer i was looking for
Old Dec 15, 2004 | 05:00 PM
gator's Avatar
Underdog
um you are welcome too jake.....
Old Dec 15, 2004 | 06:55 PM
dsmtuner's Avatar
gotta love the boost
wow it seems that not everybody knows what a 4.3 is. Did any of you know that a 4.3 is a 350 with the back 2 cyl cut ? NO. ok a 4.3 stock will beat worked civics all day long i know . OK the most free mod is to advance you distributor like 10 degrees ok then you gap the plugs a little more so your gettin more spark and a better burn . Thats like 5 more horse power ok then you go to auto zone get the edlebrock intake ok thats even better more flow another 5. If you want to spend the money get a msd ignition and a 1500 stall converter with a camaro tranny .
OH AND BY THE WAY IN ABOUT 2 MONTHS I WILL HAVE A 4.3 THAT WILL EAT LT1 I DONT CARE WHAT YOU HAVE YEAH A 4.3 WITH 350RWHP!!!!!!! (THINK ABOUT THAT)
SVT F150
Old Dec 15, 2004 | 07:06 PM
  #17 (permalink)
gator's Avatar
Underdog
dsm knows his shit. thats all i got to say......in this case, jake, you need to weld 2 cylinders onto the 4.3 and then you will have a 350. makes sense to me.
i esp liked the 1500 stall idea. my yank 4000 sucks.
Old Dec 15, 2004 | 07:17 PM
  #18 (permalink)
dsmtuner's Avatar
i built this truck from scratch from the beggining you have more options in the older4.3 non vortec non balance shafted pulling 300rwhp out of this will be easy n/a. opening up the exhaust is a big help insteap of saying PUT A LT1 SWAP. (oh and these tricks really work)
SVT F150
Old Dec 15, 2004 | 07:59 PM
  #19 (permalink)
Topless T/A's Avatar
Voice of Reason
Assemblage 23
Negative Format
I'll work to elevate you, just enough to bring you down.
Old Dec 15, 2004 | 08:36 PM
  #20 (permalink)
dsmtuner's Avatar
Dont hate because i can pull 300 hp out of a 4.3 while your still sporting your stock 95 bird dont get me wrong they are fast, quit hating.
I sure hope im not going to have to go into details
Forged pistons
Block bored 30
195 intake, 170 exhaust stainless valves, three angled valve job
100 lb valve springs
FULL roller valve train 1.5 roller rocker (non self guiding)
lunati street-strip cam shaft 150 lift
full dual exhaust H-pipe 3 inch all the way
Dynotech black hedders
Edelbrock throttle body intake and chip with a 650 cfm t/b
timing gears by cloyes
1,500 stall so i can still drive it to work everyday.
Any Questions??
SVT F150
