noobe to gas guzzling
Originally posted by kender
I had planned on the gas tank being replaced because of the baffling and was going to use the pickup and pump from the tank, on those tanks were the pumps in tank or external? why would the feed line need to be replaced? is the stock hardline not built for the pressure, Or is it the stock fittings that can't handle it? if that's the case then I'd just as soon run ss braided. on the reflash is there an edit program that will let me do it myself? I already have the eprom burner ( for most chips ) that I use for my other car, all I should need is the gui for the gm. I will stick with an auto trans that is mated to the engine that I get. I do wnat to keep a/c. I had been told that the lt1 vette engines didn't have a problem with the accessories hitting the frame. is this incorrect then? thanks for the help
One more thing: there is one thing you need to weld to use the 4L60E. The frame on G bodies built before 1985 cannot accomodate the proper crossmember for an overdrive trans without adding a little steel in the right place for a TH200 4R trans crossmember. This is done to an area like 4 inches rearward of the driver's side mounting point (IIRC) , but you should look at a 1985 or newer G body to be sure. You will need to find one anyways as you need this crossmember, unless you go with the MTS (Maximum Torque Specialties, they specilaize in Cadillac 472-500 V8 conversions in older GM cars) dual hump crossmember to accomodate a true dual exhaust.
Lastly, is the rearend. The stock 7.5 10 bolt is worthless if you ever plan to run sticky tires. The 7.625 10 bolt used in later models is a little better, but let's face it, a rear end designed for a Chevy Monza with a 2.5 liter Iron Puke is not a good choice for a V8! It will last for a while, but when it breaks, there is a stronger (if not rare ) choice. the 8.5 10 bolt. It came factory in the turbo Regals form the mid to late 80's and the Cutlass 442 and Hurst/Olds from the same time. Gearing was either 3.73 or 3.42, depending on model, and both were posi. If you get a 7.625 10 bolt from a Monte SS, you will get the crappiest Posi known to man: the Eaton Gov Lok. It is to be avoided at all costs unless free, because a free Gov Lok is better than an open diff.
Both domestics and imports have their good points.I favor neither and own both!I have:1973 AMC Javelin AMX,1979 AMC Spirit,1985 Cutlass Supreme,1995 Nissan Sentra and a 1998 Nissan Frontier.
holy shit with some nice info. so on the fuel line since the oem is too small or at least borders on too small what is the proper size, an this just means I get a bunch of a/n fittings. The lt1 accesories are what we'll use since this is my dads car (we are building it together) and he's not one to like cutting out factory metal. heck when I had to cut away part of my bumper to make way for an intercooler he almost freaked. so we (or he) would rather spend a little extra for the accesory that doesn't cause vehicle amputation. ok for the motor mounts the G body ( elcamino right?) and the fbody being the camaro/vette? just gotta make sure I'm on track. what kind of translator for the vss?? lost on this one never had to worry with the hondas ( so far).
I did consider carb since the crate engines are cheaper but this is a daily driver and makes trips out of state ( different altitude) and the efi is just easier. I'm not familiar with optispark but gather its the ignition coil system? I am not worried about wiring, as long as I have both wiring schematics I can make it work( for the money I paid for my electronics degree I'd better be able to).
the welding shouldn't be a problem, I am going to look at the cross member for the dual exhaust, but I have a mig if needed. I kinda had a feeling the oem built for 108hp would not like the 300hp that'll be thrown at it, I don't plan on stickies but I would like to get a rear end that'll hold up with room to turbo later. again thanks for the info, and patience as I feel around for the domestic stuff.
keep the good info coming.
Here's the definition of a G body: 1982-1988 rear wheel drive full frame car, 1978- 1981 A bodies are essentially the same but the designation A body was used for the Celeberty/ Cutlass Ciera, etc models starting in 1982 so GM changed the name. Models of A/G bodies include: Cutlass Supreme, Cutlass Cruiser, Cutlass Salon, Hurst/Olds, 442, El Camino, GMC Sprint (GMC's El Camino), GMC Caballero, Malibu, Monte Carlo, Malibu Classic, Grand Prix, Regal, Grand National, Century and Bonneville ( 2 yrs only). I am sure I missed some, but you get the picture. Honda has NOTHING on GM for interchangeability!
F body is Camaro/Firebird. A Corvette would be a Y body.
Opti Spark is a distributor mounted on the crank snout and not an individual coil pack system like the LS1 uses.
I drive a 1985 Cutlass Supreme Brougham with a 1977 Chevy 350 bored .030 over and a TH200 4R overdrive trans. My rear is a Monte Carlo SS unit with the 3.73, gov lok setup, but hey, it was cheap ($150) and I am on a limited budget. My car came with a 231 Buick V6/ TH200C combo with a 2.41 axle stock, so I have done a complete swap on mine. I also run Eibach Pro Kit springs, and have removed the body partially from the frame and rebushed it with an Energy Suspension Polyurethane kit. I swapped a set of the factory FE-3 suspension sway bars in 1 1/4 front and .75 rear along with the IROC Steering box that gives me 2.25 turns lock to lock. The front end has also been completely gone through with ES bushings , and I will have the popular negative roll conversion by Global West done soon, which revises the camber curve and gives you 12 in brakes to replace the 10'5 in stockers. Another thing I have is the power steering cooler form a Z-28 and a special factory aluminum hood which pulls about 30-40 lbs off the nose. A 9C1 Caprice supplied the oil cooler kit ( the car was a taxi that started life as a cop car, Copher's Tampa had about 30 of em a few years ago and I pieced mine together from those). My car runs a carburetor and was formerly a pizza delivery car, so carbs are plenty reliable. I just started mine after 5 years of sitting and waiting for me to complete the restoration and it started on the first try (but I did do the proper pre start prep).
Before yo do this, take a trip to Copher's and familiarize yourself with the different variations of 80's RWD GM cars. Most have parts that will interchange, especially between the early A, G , F, and B body cars.
