Need Help With My Jbody!
Old Feb 17, 2004 | 02:36 PM
JagnMe's Avatar
Slowey
Exclamation Need Help With My Jbody!
Yesterday I accidently opened my door without turning off my alarm and it stalled out my motor untill i found out i had to push a button to reset my alarm. After i did that it would start but the Rpms gauge wasnt not working as well as the temp gauge. Most of the warning lights also came on. I am not sure what the problem is. I may have knocked something loose when i was searching for the reset button or it could be something else. Any body have any suggestions?
Project Green Hawtness in progress.
Old Feb 17, 2004 | 02:51 PM
Topless T/A's Avatar
Voice of Reason
my remote start pulls shit like that now and then, but you just haveto reset it and wait a minute or two and everything goes back to normal..sounds like you might have a larger problem...fucked up computer or some high-tech bullshit
Assemblage 23
Negative Format
I'll work to elevate you, just enough to bring you down.
Old Feb 17, 2004 | 03:03 PM
JagnMe's Avatar
Slowey
Thats what i am thinking.
Old Feb 17, 2004 | 04:00 PM
Silverchickn's Avatar
Reset the PCM. Not sure how to do that on a J-Body as I have never looked at the procedure. But if its anything like the F-body let me know and I can get you the steps.
By the way this is just an idea and a place to start
98 Silver Formula M6
Mods: some
Old Feb 17, 2004 | 05:16 PM
JagnMe's Avatar
Slowey
So far i have tried to disconnect the battery and that didnt work and also i pushed the button under the steering collum which is supposed to reset the alarm but it seems to have fucked something up to the point where when i try to start it turns over then stalls...
