brake lights don't work
Old Feb 14, 2004 | 09:13 AM
b16a2pwr's Avatar
ALLJDM
Default brake lights don't work
ok, here's my problem:
My parking lights work, but not my brake lights. I have tested the brake light switch and that's OK. I have changed the bulbs...nothing. I have checked the fuse and that's good.
I have a 95 Chevy Lumina (car), and need some help. Can someone help me please? What do you think the problem is?
AIM: jasonbadler
813.508.PLAN (7526)
TR Notary Crew: #001
Old Feb 14, 2004 | 10:02 AM
ricola555's Avatar
replicant
Don't stop.
Buy my skateboard: http://cm.ebay.com/cm/ck/1065-29322-2357-0?uid=&site=0&ver=EOISUA080805&lk=URL&item=7189554 921
Honda Tells U.S. Auto Makers to Try Harder
(Reuters): U.S. auto makers will have to pull up their socks in the face of increasing inroads by Japanese competitors into the U.S. market, Honda Motor Co President Hiroyuki Yoshino said on Wednesday."They should try harder," Yoshino told reporters...
Old Feb 14, 2004 | 10:16 AM
Sneakin Deacon's Avatar
PSSHHH x2
look around your brake pedal, there is a little plastic button/switch thing that activates the brake lights, if it breaks off or something, it could cause that problem or its stuck.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Feb 14, 2004 | 10:23 AM
b16a2pwr's Avatar
ALLJDM
Originally posted by ricola555
Don't stop.
Haha, that'll be hard to do on U.S. 19.
I have checked the "brake light switch" and it's functional.
AIM: jasonbadler
813.508.PLAN (7526)
Old Feb 14, 2004 | 10:48 AM
PSSHHH x2
right light bulbs?
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Old Feb 14, 2004 | 11:29 AM
b16a2pwr's Avatar
ALLJDM
yes I installed the CORRECT light bulbs.
AIM: jasonbadler
813.508.PLAN (7526)
Old Feb 14, 2004 | 11:43 AM
flyinbrian's Avatar
Look for a "stop light" or "brake light" fuse.
If that turns out ok, you need to get a test light and start chasing the wires that feed your brake lights from one end of the car to the other. Check all connections as well.
Does the car have a hitch? Just wondering, possibly corrosion from tapping into the factory wiring harness when wiring for a hitch could cause this.
Old Feb 14, 2004 | 09:15 PM
grumpyoldman's Avatar
zephyrhills
brake switch bad maybe and open wire to cause it to short when u press the brake somthin in the car wired wrong to make it do this
Old Feb 15, 2004 | 05:27 AM
b16a2pwr's Avatar
ALLJDM
I have checked the fuse. It checked good, but I changed it out already. As for the brake light switch, I have checked that and it checked good, but I changed that too. I have power going to the lights, but still no brake lights. I thank everyone for the help, any and all suggestions are still appreciated.
I will be calling a parts dept. today to see if they can help!
Thanks again.
AIM: jasonbadler
813.508.PLAN (7526)
