Optispark takes a sh*t
Old Dec 7, 2003 | 01:53 PM
ZDriver96's Avatar
just curious has your local mechanic went through the basics with out using the computer to diagnose it... like Check fuel pressure to isolate it as an ignition problem? Check coil ground...
Check for spark etc...
The computer wont throw a code if the opti is bad actually. And 17 sensors dont go bad at once so its probably taht u need a new computer... Try cleaning out the terminals.. fixed my friends computer problem on his 95.
96 M6 Arctic White Z28
"SLOW LT1"
Blue 2005 Acura TSX
Old Dec 7, 2003 | 02:30 PM
TheShow50h's Avatar
The little 5.0 that could
It didn't have much pressure. I pressed the schraeder (however you spell it) valve and not much fuel came out.
Unfortunately I wasn't around when he was diagnosing the problem, or trying to. I'll definately throw those ideas his way and see what he says/thinks.
-Vince
Old Dec 7, 2003 | 06:47 PM
BigBadBuick's Avatar
Livin' Large
I know it sounds stupid, but check your fuses. I had a fuse pop and threw about 15 codes, thought I needed a computer, had the car towed, the whole deal, and it was just a fuse. The car would still run though, it even messed up the trans (had no line pressure, slipped in first) Had no idea one fuse could do so much.
Old Dec 7, 2003 | 06:59 PM
Sneakin Deacon's Avatar
PSSHHH x2
schrader valve will have little pressure when the car is not running. turn the accessories on, your fuel pump will kick on...then go try your schrader valve, should squirt pretty good.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Dec 7, 2003 | 08:29 PM
TheShow50h's Avatar
Originally posted by Mars_302
Hook a guage up to check the pressure. See if you can hear the fuel pump prime when you turn the key on. It could be your fuel pump taking a dump. But if you want help with the optispark give me a call, ive done about a dozen or so and wiould be glad to help you save some cash.
I'll definately hit you up if the optispark turns out to be the problem.
-Vince
Old Dec 8, 2003 | 12:29 PM
  #17 (permalink)
TheShow50h's Avatar
apparently the waterpump sprayed some water onto the distributor which caused it to take a shit ...
-Vince
Old Dec 8, 2003 | 07:41 PM
  #19 (permalink)
ZDriver96's Avatar
it'd be worthwhile to go to a vented style... easy to do and there are instructions on how to do it..
I ran about 10,000 miles on a water pump that was leaking on my vented opti.
"SLOW LT1"
Blue 2005 Acura TSX
Old Dec 8, 2003 | 08:47 PM
  #20 (permalink)
TheShow50h's Avatar
ok, im glad to know that we have isolated the problem.
Apparently the guy I'm going through can pick up new opti's for 120 bucks. Sounds really fishy and too good to be true to me, but we'll see how it works out and I'll definately let you all know.
on a side note ... I can't wait to feel what this car use to feel like when it was running right ... maybe it will be ready by saturday and ill take one of my seldom trips out to the race track
-Vince
