Turning X-drilled/slotted rotors
Old Jun 8, 2003 | 08:36 AM
Skillionaire's Avatar
Nobody
Default Turning X-drilled/slotted rotors
Ive got a friend with a machine for turning brake rotors but he has never done X-drilled/slotted before. Are there any certain procedures/precautions that need to be taken to do these correctly? Im going to need to do my front brakes soon.
"So...is there any tread left on the tire..or at this point would it be like throwing a hotdog down a hallway"
-Stewie (Family Guy)
Old Jun 8, 2003 | 09:39 AM
0HP930's Avatar
Guest
If the brake lathe is multi speed turn the rotors at the slow setting and only make small cuts.
It would not hurt to clean out and chamfer the cross drill holes before before and after you cut them too.
Old Jun 8, 2003 | 12:15 PM
TurboJZA70's Avatar
Old School "Turbo" dude
Tony: one of the rare few that knows how to work on real cars.
Buy a TR email address Here
Old Jun 8, 2003 | 02:32 PM
0HP930's Avatar
Guest
Its also helps to have worked at an auto parts store for years where I cut hundreds of drums and rotors.
It came in handy when I cut the porsche rotors when I did my last brake job.
Old Jun 8, 2003 | 02:40 PM
TurboJZA70's Avatar
i worked at a brake place for a wile and did crossdrills and slotted all the time wile i was there, along with my own. ever sence then it pisses me off that people refuse to cut them becouse they dont know how and cant bare to admit that the customer could accaully know more then them.
Old Jun 11, 2003 | 06:39 PM
buck19's Avatar
Forever Broke Nissan
i was always told no you cant and you have to have the right machine (like some special pixie dust). so i guess the only machine you need is with one that has variable speeds which a lot of shops have.
now youre saying take off about .003mm at a time on the lowest setting? that would take forever...
please tell me the increments you have to do them in...
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old Jun 11, 2003 | 06:48 PM
0HP930's Avatar
Guest
You can do a fast deep cut on the high end ridges that are on the undrilled areas, but when it comes to cutting over the holes I would recommending not going over 2 thousands.
You can do more per cut but it will be a lot harder on the cutting mechanism.
Old Jun 11, 2003 | 06:57 PM
buck19's Avatar
wouldnt the rotors crack from the cross drilledness
Old Jun 11, 2003 | 07:06 PM
0HP930's Avatar
Guest
I can show you hundreds of small superficial thermal stress cracks on my cross drilled rotors, but its overall structure is OK.
Its all about venting the braking surface, so I look at them as additional vent area.
Old Jun 11, 2003 | 07:23 PM
buck19's Avatar
i just dont want my rotor to shatter. i need new ones any ways. if there was a service limit on mine they would be well passed.
