Line lock
Old Mar 19, 2003 | 06:42 AM
Rotary7's Avatar
Get Down-Or-Stay Down
Default Line lock
Whats a cheap set up and are they easy to install?
How about on stock brake set up?
Do you want to be tazed?
Old Mar 19, 2003 | 07:18 AM
0HP930's Avatar
Guest
They are nothing more than a high pressure solenoid valve that is spliced into the brake line that goes to either the front or back wheels.
The difficulty involved is directly related to the difficulty of tapping into your brake lines and wiring the solenoids.
Old Mar 19, 2003 | 09:27 AM
Rotary7's Avatar
My split block for the brake lines is right next to my master cyl,
So I think it will be easy to do,I want to lock the fronts,
I got a Jegs mag,and I cant find shit,Where else can I look for it online?
Old Mar 19, 2003 | 04:37 PM
Tony's Avatar
Senior Citizen
http://www.scuderiaciriani.com/rx7/b...e_install.html
10' 1198S
09' Ninja 500R
09' Stella
Old Mar 20, 2003 | 06:34 AM
Rotary7's Avatar
Anyone else?
I dont have an ABS set up <--I should of mentioned,but its power brakes.
Old Mar 20, 2003 | 07:09 AM
mpbiv's Avatar
Rod Bearing Eater
Jeg's has the linelocks, they're hiding in the shifter section of the catalog (I would have figured they'd be in the brakes section).
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
Old Mar 20, 2003 | 07:42 AM
Rotary7's Avatar
Ok thanks,let me check my Jegs book..
