The 20-Minute Japanese Trick to Unclog a Catalytic Converter (Zero Tools Needed)
Old Feb 19, 2026 | 08:29 AM
Default The 20-Minute Japanese Trick to Unclog a Catalytic Converter (Zero Tools Needed)
SUV Insider
7.44K subscribers
97,815 views Feb 14, 2026
Old Feb 19, 2026 | 08:35 AM
Default Cataclean…Science or Scam? Codes P0420 / P0430
Hey You Can Fix It!
1.19K subscribers
148,867 views Apr 6, 2025
If your car pops up a catalyst efficiency code (P0420/P0430) and you look for help on YouTube you will find all sorts of videos about some magic juice called Cataclean. In this video we try out Cataclean, find out what is actually in it and try a much cheaper alternative as well. Will it work? If not what is a kludge/patch/hack that might turn off your CEL for a catalytic convertor that is still mostly OK?
Old Feb 19, 2026 | 08:37 AM
Default How to Clean Your Car's Catalytic Converter using Lacquer Thinner
Scotty Kilmer
6.62M subscribers
5,415,221 views Feb 3, 2011 #savagescotty
Catalytic converter cleaner. How to clean catalytic converter DIY with Scotty Kilmer. Catalytic converter clogged and problem code P0420. How to fix and repair bad or clogged catalytic converter in your car by cleaning it with lacquer thinner cleaner (life hack). Replacing a catalytic converter in your car can be expensive, but this hack can help fix it cheap and fast. DIY car repair with Scotty Kilmer, an auto mechanic for the last 43 years.
Old Feb 19, 2026 | 08:40 AM
Default Cleaning Catalytic Converters with Sodium Hydroxide -EricTheCarGuy
EricTheCarGuy
1.84M subscribers
1,622,463 views Aug 29, 2014
Let's face it, replacing a catalytic converter can be expensive. So if there's a way to clean them, I'm sure you'd rather try that first before paying good money for a new one. After 2 other attempts to clean my catalytic converters I've decided to try sodium hydroxide this time. In my previous attempts I did not follow the recommended procedure for cleaning. In this video I make sure that I follow
a procedure that will hopefully yield a result and allay any concerns about my cleaning methods. Let's face it, catalytic converters can be expensive, very expensive. If there's a way to clean them over replacing them, I'm sure you'd want to give that a try before you shelled out the big bucks for a new one. So in this video I show you another possible method of cleaning your catalytic
converter. Remember this isn't even worth trying if your catalytic converter is physically damaged. Also, be sure to fix the underlying problem that caused the catalytic converter not to function in the first place. If you have a misfire or an engine that burns a lot of oil, be sure and address those issues as well, if not, you'll likely be right back where you started in short order.
Old Feb 19, 2026 | 08:42 AM
Default How To Clean A Catalytic Converter (Without Removing It !)
Mechanic Base
68.1K subscribers
178,353 views Mar 6, 2025
Learn how to clean your catalytic converter without removing it, a simple and cost-effective solution to improve your vehicle's performance and fuel efficiency. In this video, we'll explore the methods and techniques to clean your catalytic converter, helping you to avoid costly repairs and replacements. Whether you're a car enthusiast or a novice, this video will provide you with the information you need to keep your vehicle running smoothly and efficiently. Discover the benefits of cleaning your catalytic converter and how it can help to reduce emissions, improve engine power, and save you money in the long run. Find out if cleaning your catalytic converter without removing it is the right solution for you and your vehicle.
Old Feb 19, 2026 | 08:44 AM
Default How to clean catalytic converter while on car, customers request to spray down with c
How to clean catalytic converter while on car, customers request to spray down with cleaner
RB The Mechanic
158K subscribers
993,343 views Oct 13, 2021 #p0420#catalytic#catalyticconverter
Due to factors beyond the control of RB The Mechanic, it cannot guarantee against unauthorized modifications of this information. RB The Mechanic assumes no liability for property damages or injury incurred as a result of any of the information contained in this video. RB The Mechanic recommends to follow safe practices when working with power tools, automotive lifts, lifting tools, jack
stands, electrical equipment, chemicals, or any other tools or equipment seen or implied in this video. Due to factors beyond the control of RB The Mechanic, no information contained in this video shall create any express or implied warranty or guarantee of any particular result. Any injury, damage or loss that may result from improper use of these tools, equipment, or the information contained in this video is the sole responsibility of the user and not RB The Mechanic
Paint, Body, and Detailing
Sep 1, 2024 08:25 PM
Guns & Ammo
Sep 25, 2022 05:55 PM
May 28, 2017 03:59 AM
May 28, 2017 03:41 AM
