Hurricane generator advice
Old 06-23-2018, 02:48 PM
Default Hurricane generator advice
We had a hurricane pass through and we were w/o power for 11 days.
I had a 5000KW generator I bought from a big box store. Forgotthe brand.
I bought two 110v window units. Not sure of the brand - got them at Home Depot.
I had two refrigerators running off the generator along with the two A/C units.
Probably had a cell phone charger and a few lamps.
When I bought the generator (post storm), I bought the largest gauge extension cords that I could find and tried to keep the length to less than 50'.
Look at the generator and make sure you're running an A/C and a fridge on one "leg" (don't plug A/C and fridge into one cord).
My extension cords looked like spaghetti but whatever I did worked. I put the generator away from my house so we didn't have exhaust fumes.
My generator ran 24/7 w/o a problem. The only time i turned it off was to change the oil (buy the oil when you buy the generator) or to refuel (I let my generator cool before I put gas in it).
All that said - you need a lot of gas to run a generator round the clock. I think i had to add fuel about every 8 hours but I'm not sure.
My other advice is practice this drill at least once before hurricane season. Do a dry run (your wife will think you're nuts).
You want to figure out all the issues while you have real A/C in your house and your big box store is not out of supplies.
That my two cents.
Old 06-23-2018, 02:51 PM
A 3,500W unit will power a 10,000 BTU AC unit and a little extra. If you want to run more or around the clock you need to consider that. I have a 6,800w/8,500w surge Home Depot special. I'll run one of my 2.5 ton AC units at the house, 2 frigs, TV, a few lights without issue. If you're ust running the AC unit a Honda 2000 or the like would likely work but those aren't budget conscious gensets.
Its sounds like you might want to consider that $699 unit from Harbor Freight. I already have a couple Hondas but I'd look at them hard if I was shopping.
Old 06-23-2018, 02:52 PM
We have had a PowerBoss 8125/6500 ever since Charley/Frances/Jeanne. It provides power for 2 window ACs, 2 refrigerators, misc lights, etc. We have a hardwired transfer switch for 12 circuits in two zones that displays wattage consumed for each zone. The generator is extremely loud and needs to be refueled (6+ gallons) every 8-10 hours.
After Irma last year I got tired of the noise and fuel consumption of the 'big' generator so I purchased two of the Wen 2000 watt inverter generators, Wen parallel connection kit, and a dual fuel feed and 6 gallon fuel tank. One of the Wen generators was able to startup/run a 12000 BTU window air conditioner, however the generator would bog down when the compressor kicked in. With both Wens paralleled they were able to run both window ACs (12000, 8000 btu), both refrigerators, lights, etc and they will run for about 44-48 hours before needing to be refueled. And they are so much quieter that they cannot be heard at all from inside the house. I plan to keep the Powerboss 6500 as a backup or to 'lend out' in the event of the next hurricane that knocks out our power.
Old 06-23-2018, 02:54 PM
I think if you manage your power use, you can get by with a smaller genny than you might think. As usual, I researched this to death, and came within a keystroke of buying a pair of the Champion 2000w units, and then the WEN 2000w units, to run in parallel, but got cold feet and just ordered a Honda EU2200i. I'm hoping I can run my fridge and a 6,000BTU wall unit. The EU2000i will run a 6,000BTU wall unit with ease, so I'm hoping the extra 200 watts and larger engine in the EU2200i will be up to the task of adding a fridge to the mix. Running watts in a worst case scenario is around 1,300 for both, and I think the only time I might have an issue is if both cycle on at the same time. I was able to calculate the fridge surge watts at 1,400 based on the LRA rating of the compressor. The window AC is the wild card, but I'm thinking maybe 1,000 watts if it's Energy Star rated. The Honda's are conservatively rated I believe, as I've seen them easily power appliances that shut down other genny's with the same wattage rating.
The one thing I learned about the fridge is that the amp draw indicated on the data plate is the max it will draw if all functions were operating simultaneously (defrost circuit, compressor, ice maker, etc.). It's unlikely that the defrost circuit and compressor would run at the same time, so I think running watts under normal conditions is less than 800, perhaps more like 500, so my total running watts is probably going to be 1,000. If the EU2200i can survive a 2,400 watt surge for 1 second, I'll be good to go. I guess worst case is I have to buy the Companion unit and run it in parallel. Realistically, I'd probably just run the fridge during the day, the AC and night, and go through a 4 hour cycle with the fridge. By the way, a 6,000BTU unit will cool 250sq/ft, so you might get the room comfortable with that, otherwise move up to 8,000BTU. I think the power consumption goes up quite a bit above 8,000BTU's.
I cringed at the $900 price, but I wanted something I could put 100% trust in.
Old 06-23-2018, 02:57 PM
http://www.consumerreports.org/inver...er-generators/
One of the most important aspects of an inverter generator compared to a 'normal' generator is that a normal generator ALWAYS runs at whatever fixed speed is required to produce 60HZ AC power. This means that 99% of the portable gas generators run continuously at 3600 RPM (some diesel generators run at 1800 RPM) ALL THE TIME regardless of the electric power being consumed. Whereas an inverter generator is not dependent on the fixed RPM to produce 60HZ AC so they can speed up/slow down to match the actual WATTS load. Therefore they are typically much quieter and much more fuel efficient (as well as producing a much better AC sine wave which is much safer for sensitive electronics/motors)
Old 06-23-2018, 02:58 PM
My travel trailer becomes sanctuary. 3500 w electric start (for the wife),dual fuel, inverter generator runs the 13.5 btu AC, plus the frig, freezer TV and lights. As long as the trailer is still there after the storm I'm good. If not, my 13 KW pto generator gets hooked up. Truck holds 44 gals of diesel and the boat holds 120 gals of gas.
I have a plan... and so far it's worked when needed.
10-16-2018 04:58 AM
05-23-2018 03:43 AM
Quick Reply: Hurricane generator advice
