debate
Old Feb 13, 2003 | 03:46 PM
MoNoXiDe_ChIlD's Avatar
wickid clown
Default debate
ok me and a friend were in a debate about the new nissan sentra ser spec v i dont understand y u would want a 4cylinder 6 speed manual trans except 4 high speeds he seems 2 think it would b faster at acceleration i dont know if it would b like lets say u raced 1 with an integra type r or some other 5 speed 4 cylinder what would win in the 1\4 and what is good about a 4 cylinder 6 speed i just dont get it help me!!!!
Old Feb 13, 2003 | 04:10 PM
0HP930's Avatar
Guest
Here are the pros and cons of more gears.
Pro - More ratios allow you to keep the engine in the peak powerband through a wide range of speeds. You can also have a good low gear and top gear.
Con - More gears mean more shift points, and you can't accelerate while shifting. More gears in a limited amount of space also means a weaker tranny than less gears in the same box.
Here is also a case in point. My car is the last model that came with a 4 speed tranny. The five speed model that was identical except for the tranny had exactly the same performance numbers as the four speed. The 5 speed is also a weaker tranny than the four speed. My four speed is rated for 700 HP, where the five speed was rated for only about 450 HP.
Part of the reason why the 4 speed does as well as the 5 speed in the case of my car is since it has a wide torque curve.
Cars with peaky power points are more likely to benefit from more gears.
Old Feb 13, 2003 | 04:25 PM
Tom's Avatar
Tom
Strict Machine
Default Re: debate
punctuation pwns you
2012 FIAT 500 ABARTH
Old Feb 14, 2003 | 02:49 AM
Tits McGee's Avatar
is cooler than you
Spec V's suck. No brand new car should have clutch shudder, and the one I drove did. Seats felt like sandpaper.......performance was less than stellar. I'll keep my Integra.
