Sc400 help
Old Apr 30, 2012 | 04:43 PM
chriscarr's Avatar
Default Sc400 help
Anyone know where to diagnose a 95 sc400 (obd1)? noone seems to have the scanner for obd1...... just 96+ ... Car runs great for 15-20 mins of driving.. after that the idle begins to drop and sometimes it stalls and bogs.. did spark plugs... rotors.. caps... wires... air filter.. any info is appreciated..
Old Apr 30, 2012 | 06:30 PM
Thaking's Avatar
lol wut?
MAF? Clean it out and use the specialty cleaner for it not carb cleaner.
Old Apr 30, 2012 | 07:28 PM
flatrex's Avatar
crx hatch sedan
This took 2 seconds to search for 92-95 Sc300/sc400 Obd1 Code Retrieval - Lexus Owners Club (USA & Canada) how to pull codes on 95 sc400 - Google Search hope this helps
Old Apr 30, 2012 | 07:40 PM
chriscarr's Avatar
already did the maf cleaning with maf cleaner the CEL dosent come on at first.. when it begins to stumble and drop in rpms then it comes on. going to check flatrexs link ty guys
Old Apr 30, 2012 | 08:23 PM
Empire's Avatar
buildin' it
sounds like a vacuum leak, and/or weak fuel system.
could be something dumb like a coolant temp sensor too.
Old Apr 30, 2012 | 08:32 PM
Lay Maha's Avatar
Jaded Mitsu
my 93 ls400 had the same problem, until I swap out the ecu, because the caps were leaking. Try driving your car until the problem occurs and disconnect the battery to reset the ecu. Are you on clublexus.com?
Old May 1, 2012 | 08:16 AM
Kabron's Avatar
Blood In Blood Out
Check any vacuum lines around your engine bay for cracks and tears.
VATO LOCO FOR LIFE
Old May 1, 2012 | 02:54 PM
chriscarr's Avatar
Wouldn't the vaccum hoses cause this problem upon startup? they look ok to me, no cracks or tears.... yesterday I* took out the fuel pump fuse after the problem happened for about five mins then put it back in..... same shit... with the MAF unplugged it runs like complete shit...so i dont think its the maf.. how would i check if it is the coolent temp sensor? How long does the battery have to be disconnected for it to reset the ecu?
Old May 2, 2012 | 08:33 PM
Empire's Avatar
buildin' it
if the vacuum leaks are really bad, then yes, you would have problems right at start up. however, if they are just cracked, then it can take a while for the heat to build up, expand the cracks and leak.
It could also be something dumb, like a vacuum line used in an emissions system that doesn't get activated until certain conditions.
or, it could just take that long for the ecu to change the fuel map enough for the issue to really come through.
I was working on a car a while back that had that same problem. But it was tough to diagnose because the girl that was driving it, only had a 4 mile commute. The car was barely warmed up at that point. So the ecu was still in the "engine is cold" fuel map. But after driving much further, and the ecu changed the fuel map because the engine was hot, it would run like total balls.
The 300zx I just got done putting together ran great, until you were cruising on the interstate, then it would run like shit. It was because on the the vacuum lines related to the egr valve was rotted and the egr valve system was only activated during light load cruising.
at the very least, you want to rule out the possibility of a vacuum leak.
the other thing I would look at is the fuel system.
I would want to know if an injector was taking a shit on me once the resistance built up.
same thing with the fuel pump.
I mentioned the coolant temp sensor because it can cause all kinds of issues (with nissans at least, some cars don't use the CTS so much, I'm not sure about toyotas) Given the amount of drive time it takes for the issue to really happen, the coolant temp could explain it.
and to reset the ECU.
Unless you find the exact time, the general rule of thumb is at least an hour.
and/or, disconnect the terminals, and then touch/hold the terminals together, that will discharge any stored voltage.
usually reseting the ecu isn't a big deal with OBD1 cars though.
Old May 3, 2012 | 10:01 AM
chriscarr's Avatar
^^ thanks for info
sc400varg
Jul 24, 2011 07:46 PM
s13rb-x
For Sale/WTB Toyota
Jul 19, 2011 06:43 AM
s13rb-x
For Sale/WTB Toyota
Jun 25, 2011 09:17 AM
skim17
Jan 22, 2010 08:58 AM
JonNoH
Jun 18, 2009 09:35 PM
