HELP !!ASAP!!!
Old Nov 25, 2002 | 05:13 PM
MikeB's Avatar
Default HELP !!ASAP!!!
how do you get a stripped lug nut off, it looks like that someonetried o steal it and they couldnt get it off and now its stripped!! how do i get it off????thanks in advance (from spencedogg)
-mike-
Old Nov 25, 2002 | 05:19 PM
0HP930's Avatar
Guest
Rent a nut cracker. Its kind of like a bolt cutter for nuts.
Then again it will only work if your lug nuts are out in the open where you can get to them.
Old Nov 25, 2002 | 05:27 PM
MikeB's Avatar
hey will you give spencer(spencedogg) a callat 813-841-8397 he needs help bad with this liek rightnow cal him thanks in advance
-mike-
-mike-
Old Nov 25, 2002 | 06:17 PM
sciloteous's Avatar
If you can get to it you can rent a blow torch and cut it.
AIM-sciloteous
Old Nov 25, 2002 | 09:44 PM
Spence's Avatar
"TEAM WHITEY"
he forgot to mention that it is a tuner lug nut that looks like a socket
REPRESENTING PORTLAND OREGON THE WEST COAST TR MEMBER
Old Nov 26, 2002 | 10:09 AM
BlackZ28's Avatar
ppssshsshhhhhhh
go to tire kingdom, they can get if off for u. its like $20-$30 bux. or if u know them its free
Old Nov 26, 2002 | 05:20 PM
Spence's Avatar
"TEAM WHITEY"
to the top
Old Nov 26, 2002 | 06:27 PM
0HP930's Avatar
Guest
From what spence has told me at this point I would assume the only remaining options are drilling out the stud from the center of the nut or taking a torch to either the nut side or the hub side of the stud.
Anyone else have any additional options in mind?
Old Nov 26, 2002 | 07:20 PM
svtjesse's Avatar
Yeah its a 12mm allen bolt inside the lug, I took a Allen Key and the inside of the nut was so stripped out that it wouldnt work, and even a 13MM wouldnt work, so I took a brand new drill bit for steel and drilled out the lug, but when I hit the Stud it wouldnt go any further, and I am out of oxygen in the damn torch
But I think Drilling it out is the best way, least likley to hurt the wheel.
Jesse
Old Nov 26, 2002 | 08:22 PM
Spence's Avatar
"TEAM WHITEY"
top
