help!!!!!!!
Old May 27, 2002 | 04:43 PM
mpbiv's Avatar
Rod Bearing Eater
In order of likliness
Scenario one: Battery screwed starters use a lot of amperage to turn a engine especially if it has a lot of cylinders. It wouldnt be unusual for everything else to work but the car wont start. Sometimes you will get a clicking noise from the relay or the starter but the engine will not turn over.
Scenario two: Alternator died and your battery is just discharged. Jump it if it dies when you remove the cables than the alternator is the likely problem. Or if it doesnt die and you are daring enough you can remove the battery while it is running and if it dies then it is a alternator problem thats assuming your battery still has enough amperage to run the car but not start it. If niether of these actions make the car stop running than it is the battery.
Scenario three: Starter is gone.
Just from my experience its always best to start with the battery in this situation. In most cases it is not the starter its usually the battery or the alternator but mostly the battery.
In your case it sounds exactly like a dead or dying battery. I had this happen to me once because whoever I bought my car from put a small lawnmower battery in it which eventually overtime was damaged from overcharging by a system made for a larger battery. It all happened one morning I went to start it got the same problem you stated clicking and all. Had it jumped ran fine so I got a new battery and no problems since.
Sorry for the long explanation
Patrick
05 SRT-4: Daily Driver, 11.9@117.4
88 Aries: 2.2L Turbo (Powered by Megasquirt II)
Old May 27, 2002 | 05:58 PM
GearGrinder's Avatar
ridin high
thanks for the help
but the car will not jump start
we tried and she still made the clicking noise
i think its the starter
i called the guy who i bought it from and he towed it to his shop and is going to fix it in the morning
Own an APBT? visit... www.mypitbullpro.com
