The Dark Star................
Old Jan 26, 2002 | 05:31 AM
Joker's Avatar
Eat My Ass With a Spoon
this is my favorite dsm John Shepards 9 sec street class 1G.
This thread was brought to you by "Joker's ButtSeXxX" railing your sisters tarstar since 1992.
Old Jan 26, 2002 | 05:33 AM
Joker's Avatar
this is the article on this car from this months current turbo magazine.
We see a lot of different cars here at the editorial offices of Primedias International Performance Group. Working off and on at five different magazines I think Ive probably seen them all. Truth be told Ive seen some pretty stupid ones but Ive also seen a lot of crazy fast ones. In terms of all-out performance the most impressive are without a doubt track-bred competition racers cars that make 400 500 600 or more hp with totally stripped interiors rock-hard race suspensions and super-soft track-only tires. The kind of cars which make emissions control technicians and EPA tree-huggers wake-up screaming in the night.
For real-world performance and practicality--after all isnt that what production vehicles are all about? The most impressive cars are the ones that run sick numbers at the track then drive off the asphalt onto the street and all the way home without so much as having their wheels changed. Such is North Lawrence Ohio resident John Shepherds claim to fame. His car the 1991 Eagle Talon pictured is used as a sometime daily driver but remains capable of turning high 9s down the quarter mile without any track-day modifications and on the same street radials that get Shepherd to and from work. It is in fact the first street-class car to run in the 9s since the IDRC changed its rules to allow only radial tires in competition.
At the time Shepherd purchased the car from none other than famed DSM tuner David Buschur it was already heavily modified and running in the 11s. Since then the only things that remain the same are the body paint wheels intake manifold and fuel cell and Shepherd has managed to shave about two seconds off the cars low e.t. Initially he was able to work the Talon into the 10s by tinkering with the original 20G turbo setup but as Shepherd himself says It was not enough.
In the following months Shepherd rebuilt the 4G63 powerplant and overhauled the existing forced induction system to make this Talon the confirmed 9-second scorcher it is today. Block machining duties were handed to Story Motors in Massillon Ohio but actual assembly was carried out by Shepherd himself. Forged Crower rods link a factory crankshaft to 8.5:1 Ross pistons. The oiling system remains untouched. BCE Racing in Rancho Cucamonga Calif. modified the head by enlarging the ports for oversized (1mm larger) stainless-steel valves on both hot and cool sides. These valves are actuated by HKS camshafts with 272-degrees of duration on intake and exhaust sides. The valves return to their seats via doubled-up springs and titanium retainers keep them in check. The rest of the valvetrain remains the way Mitsubishi (whoops I mean Eagle) built it.
The forced-induction system was upgraded using an HKS manifold which supports a new T4 turbocharger fabricated to Shepherds specifications by Forced Performance in Kyle Texas. After driving the turbine wheel wasted gases are piped out the back through a high-flow 3-inch Buschur Racing exhaust system. On the cool side the charge air is piped through a Buschur Racing intercooler setup based around a 22x14-inch front-mount Spearco core and directed into a Buschur Racing intake manifold. Fuel enrichment and ignition duties are masterminded by a Professional EFI Systems stand-alone engine management computer. This fully programmable unit directs an augmented fuel system featuring an SX fuel pump SX pressure regulator and RC Engineering injectors. For extra thrust a Nitrous Express 100-shot single-nozzle injection system has been plumbed into the intake tract. The application of nitrous is also controlled by the Pro EFI computer delivering 100 hp according to pre-set engine rpm and throttle angles determined by Shepherd and his trusty lap-top computer.
The drivetrain has been bolstered with an an ACPT carbon-fiber driveshaft and ACT 3200-lb pressure plate and street disc clutch assembly which actuates a lightened Fidanza flywheel. The transmission was reassembled by Shepherd according to his own formula for success--but retains its original factory gear ratios. The factory differentials remain in place.
In the interest of preserving the drivetrains mechanical integrity Shepherd has developed a unique way of launching his DSM street rocket out of the hole so no undue stress is placed on any of his carefully selected and assembled components.
I try and ease it out of the hole and sacrifice my 60-ft times to keep the car together he says. I asked him if he ever just drops the clutch and he replied with an emphatic No. So far his method seems to be working with no reliability problems to speak of.
While the sedate factory-looking exterior wont overtly state this cars true nature other than the Spearco core staring ominously through the front bumper a look inside the cars interior will give you an idea of this machines latent performance potential.
Shepherd still calls it a street car and drives it that way a couple times a week but the cockpit is definitely Spartan--crank windows no A/C. The factory carpeting is still there but all seats have been removed. The drivers seat was replaced with a Summit Racing bucket strapped with a RCI harness. The dash has been crammed with various electronic equipment including five Auto Meter gauges reading oil pressure water temp boost fuel level and fuel pressure a GReddy system meter reading EGT the nitrous toggle switch and the HKS EVC electronic boost controller.
A Momo tiller keeps the car pointed down the straight and narrow. The six-point chrome-moly cage you see in the pictures has since been upgraded to an NHRA-approved 12-point chrome-moly frame fabricated by Gary Reese Chassis.
Suspension mods have been limited to a DSS coil-over system and a Suspension Techniques anti-roll bar in the rear. Mods to the brakes have been limited to braided lines for better pressure delivery. The Talons rolling stock 16x8-inch Volk TE37s and Toyo RA1 tires sized 225/50ZR-16 is what Shepherd uses on both street and strip. The cars best 1320 jaunt to date 9.89 sec. at 148 mph was made using the Volk alloys and Toyo rubber.
Those involved in IDRC racing especially street class or DSM racers will undoubtedly know Shepherds name. He was kicking ass and taking names at IDRC events all last season winning six out of six races. For the new season he says hes interested in pursuing the top names in NHRAs import drag series. Considering what hes done with this car I would think the NHRA street class competition and Ari Yallon who ran the table himself in 2001 winning all the NHRA events may start to feel the heat on their respective backsides right about now. Keep an eye on future IDRC and NHRA street class races for more on the first Street-Class DSM to blast into the 9s.
Old Jan 26, 2002 | 05:34 AM
Joker's Avatar
Old Jan 26, 2002 | 05:36 AM
Joker's Avatar
Old Jan 26, 2002 | 05:45 AM
b16a2pwr's Avatar
ALLJDM
good lord. I bet he doesnt break down as much as ALAN.
sorry alsn I had to do it@
AIM: jasonbadler
813.508.PLAN (7526)
TR Notary Crew: #001
Old Jan 26, 2002 | 05:52 AM
Epicman's Avatar
Me angry, you cry
Now thats a sleeper right there. That thing is fucking badass.
Old Jan 26, 2002 | 08:12 AM
charissa's Avatar
maybe memories
Shrek owns
Old Jan 26, 2002 | 09:31 AM
Moriarty's Avatar
Yum! Anyone else see the new Turbo issue with this and the other two DSMs? Very nice. That tube frame one from Buschur Racing is pretty insane.
=========|Chris|=========
