Youll get a kick out of this
Old Jan 19, 2002 | 09:29 PM
Robster's Avatar
Ok weve all been there you get a bolt on product you set aside 30 minutes to put this product on and have plans to go somewhere afterwards. Its just a bolt on no biggy so you pull the car in the garage and get to work you got places to go. So bam you get the old part off a breeze and bam all the fucking sudden you run into a problem and that 30 minutes is now going to take the hole fucking day. So go ahead and tell your install gone bad story.
Ill start first. So I pick up a cam gear make plans with my g/f she lives out in BFE (bum fucking egypt for those of you not up to date on your abbreviations) so I have an hour before she gets here. Well how convinient. Me being a guy only takes about 1/2 hour to shower get dressed and everything else Id do before I go out somewhere. And the cam gear technically its only one bolt I need to undo slide the timing belt off slide in the woodruff key put the new gear on line up the tdc marks on the crank slide the timing belt back on and Im done. That should only be a half hour right...........WRONG. While I was doing this I was having a little trouble sliding the timing belt back on VERY tight fit so I figured no biggy Ill just mark the groove on the cam gear the groove on the timing belt take the cam gear off the cam and put the cam gear in the belt grooves and slide the cam gear onto the cam. Well as I was sliding the cam gear back off the cam the fucking woodruff fucking key fucking falls fucking in the fucking god fucking damned fucking timing fucking belt fucking cover FUCK! I have to fucking find this thing I cant just let a woodruff key float around inside the timing belt cover. If this some how gets into a tooth on the oil or water pump gears the tensioner pully it could easily chew up the belt and cause it to snap in a non-clearance motor. This wouldnt be so bad on some cars but those who are familar with hondas know how damn close the timing belt cover is to the side wall of the engine bay making it very cramped corners to work. It would be even easier if I had a large enough air compressor and impact gun or even the moroso crank pully bolt remover tool. But no I dont have any of that. So I take all the little bolts off on the timing belt cover so I have a little bit of play with it. I start pulling on it in different directions trying to look down in each little crevice with the flashlight. No fucking luck. I take the dremel and start cutting holes in the cover in areas that I think it may be in. Finally I found the woodruff key. After half an hour of trying to get it with a magnet I finally got it. So after 4 hours of trying to simply put on a cam gear Im done. Fuck You woodruff key. I need a fucking beer.
Robster
You have now seen the entire internet good bye.
Old Jan 19, 2002 | 10:41 PM
John's Avatar
lol @ tampa
1 g07 0|\|3 f0|2 y4...
D01|\|g 4 v4lv3 5p|21|\|g 1|\|574ll 0|\| 4 cu570m3|25 c4|2 |\|07 700 l0|\|g 4g0. 51|\|c3 \^/3 h4v3 7h3 p|20p3|2 700l5 \^/3 d0|\|7 h4v3 70 |23m0v3 7h3 h34d 70 d0 17 50 7h1|\|g5 4|23 g01|\|g 5l0\^/ 45 175 |\|07 7h3 3451357 1|\|574ll 1|\| 7h3 \^/0|2ld. \^/3|23 |2u|\||\|1|\|g b3h1|\|d 4|\|d 175 |\|34|21|\|g 124m. 0|\| 7h3 v3|2y l457 v4lv3 5p|21|\|g (1 5h17 y0u |\|07) 0|\|3 0f 7h3 k33p3|25 (\^/h1ch h0ld5 7h3 |23741|\|3|2 0|\| 7h3 v4lv3 v3|2y 5m4ll) p0p5 0ff 4|\|d 15 |\|0 \^/h3|23 70 b3 f0u|\|d. Fuck m3. 50 \^/3 b|234k 0u7 7h3 7|2u57y m4g|\|37 0|\| 4 571ck 4|\|d f0lly 4|20u|\|d h0p1|\|g 70 h17 g0ld 1|\| 7h3 01l |237u|2|\| p4554g35 1|\| 7h3 h34d. |\|0 d1c3 \^/3 |234ch3d 7h3 01l p4|\| \^/17h |\|0 luck. 175 |\|07 0|\| 7h3 g|20u|\|d 175 |\|0 \^/h3|23....175 g0774 b3 1|\| 7h3 01l p4|\|. 14m |\|0\^/...\^/3 d|241|\| 4ll 7h3 01l 0u7 0f 7h3 m070|2 4|\|d 57|241|\| 17 \^/17h 4 7 5h1|27 70 p3|2h4p5 f1|\|d 17. |\|0 d1c3 4g41|\|. 71m3 70 pull 7h3 01l p4|\|...1304m.
Pull 7h3 01l p4|\| 4|\|d \^/0uld|\|7 y0u k|\|0\^/ 175 51771|\|g 7h3|23. \^/3 m4|\|4g3d 70 f1|\|d 3|\|0ugh 01l 70 g37 7h3 c4|2 g01|\|g 4g41|\| 4|\|d f1|\|15h 7h3 j0b 47 2304m. Fuck 7h47 5uck3d.
2008 AW 335xi coupe - Dinan stage 2 - DCI - Dinan axle back
|Full color business cards||flyers||postcards||more|
Old Jan 20, 2002 | 04:56 AM
BIG_Truck_Driver's Avatar
Wherever I may roam...
Over the summer it took us almost 7 hours to install my springs and shocks......the front only took an hour....but the rear ended up taking forever....had to disconnect the control arms and such....thankfully I just got to sit there and watch cause I couldnt be much help with two other boys working on it.
Oh and yesterday it took my best friend and a mutual friend of ours like 5 hours to install new rotors and brake pads on his Civic. But Im sure we were just doing it the difficult way and it really only shoulda took like 45 minutes. But at least we had fun....cause playing with cars is cool.
Old Jan 20, 2002 | 06:44 AM
Sangui's Avatar
Kung Fu Hustler
Damn Robster that sucks. Whenever I do any Installations now I mulitply the said time by 4. Because it usually ends up being something stupid that holds you back.
"The kingdom of heaven lies within the mind, heart and soul, of all men. To realize it we need only to overcome our own selfishness."
Shinmantis:Muuuuuggggeeeeennnn!
JohnWhizz1800:BBBOOOOOOOSSSSSSTTTT! F Mugen
John Whizz1800:Mugen =136 ft lbs
AIM: Shinmantis
Old Jan 20, 2002 | 06:45 AM
Sangui's Avatar
Kung Fu Hustler
AIM: Shinmantis
Old Jan 20, 2002 | 07:15 AM
MR2driver's Avatar
not available
Double Post!
Old Jan 20, 2002 | 08:03 AM
b16a2pwr's Avatar
ALLJDM
thats why I try as hard as possible NOT to work on my car!
AIM: jasonbadler
813.508.PLAN (7526)
TR Notary Crew: #001
