Help me solve my Car Problems!!!!
Old Dec 1, 2008 | 09:48 AM
DeLSoLRo's Avatar
I Drive Slow
Default Help me solve my Car Problems!!!!
Problem 1:
fixed
Problem 2:
Sometimes pulling out of first, it will make this whistling high pitched "WOOOO-ing" noise from behind the dash/firewall. Pretty sure its the 3 puct 6 spring clutch but friend said it might be the throttle cable hitting the firewall?
Problem 3:
Whenever vtak engages in 3rd or 4th gear, my check engine light will come on and it throws a code 21. The guy who had the car b4 me told me that the vteck ground cable from the ecu isnt hooked up to a proper ground (its on body right by where the ecu is). the wire is spliced and im gonna try to solder it, but i need to find out what would be a good ground for the vtec ground cable coming out of the ecu?
Problem 4: After a while when the car is hot sometimes the idle will go all the way down to like 200-300 instead of 800
For Sale
99 Civic Coupe - $3600
Old Dec 1, 2008 | 11:47 AM
TIM TIM TIM's Avatar
could be worse
problem 2 could be the clutch.. is it an aftermarket?
aim:because tim said
Old Dec 1, 2008 | 12:18 PM
Garrett's Avatar
pfft.....
problem 1 sounds like its just a bad catalytic converter. Thats about what mine was doing until i removed it and just ran a test pipe instead.
Old Dec 5, 2008 | 05:58 AM
DeLSoLRo's Avatar
I Drive Slow
its got an aftermarket clutch, i dont remember wat it was but something with a 6 and a 3....
^it doesnt have a cat, just straight piping all the way back but im gonna try to get new piping soon...
For Sale
Old Dec 5, 2008 | 06:00 AM
Garrett's Avatar
pfft.....
check the manifold and for exhaust leaks....
Old Dec 5, 2008 | 06:16 AM
DeLSoLRo's Avatar
I Drive Slow
the exhaust doesnt really bother me that much since its getting new piping, what bothers me is the other 3 things
For Sale
Old Dec 25, 2008 | 11:40 AM
DeLSoLRo's Avatar
I Drive Slow
ttt...
For Sale
Old Dec 25, 2008 | 12:20 PM
P057's Avatar
isuck
3rd:
basically any large body of metal, such as a sanded down, unpainted portion of the frame of the car would work.
I have a doubting feeling about it being a grounding issue to cause a CEL, but it should be done anyways.
Originally Posted by TNathe
so because wikileaks doesnt have it means it didnt happen? Now there's some logic!
Old Dec 25, 2008 | 03:25 PM
DeLSoLRo's Avatar
I Drive Slow
^the cable is spliced, so im gonna solder a new piece of wire, and see if it still does it...it i will only do it when the throttle is all the way down...
For Sale
