So Ive been wondering...
Old Aug 29, 2001 | 09:10 PM
John's Avatar
lol @ tampa
0f m057 0f 7h3 c4|25 1 \^/0|2k 0|\| m057 0f 7h3m 4|23 H0|\|d45. 4|\|d m057 H0|\|d45 4|23 |23l471v3ly 51mpl3. Bu7 4 f3\^/ 0f 7h3m (4|\|d 4 l07 0f 07h3|2 c4|25) h4v3 3G|25. C4|\| 50m3b0dy 3><pl41|\| 70 m3 \^/h47 7h3y 4|23 4|\|d \^/hy 7h3y \^/0uld \^/4|\|7 70 |23c1|2cul473 3><h4u57 g45535 1|\|70 7h3 1|\|74k3 57|234m? 3|\|l1gh73|\| m3.
2008 AW 335xi coupe - Dinan stage 2 - DCI - Dinan axle back
|Full color business cards||flyers||postcards||more|
Old Aug 29, 2001 | 09:26 PM
Epicman's Avatar
Me angry, you cry
Come again? Never heard of any of this. Please enlighten the both of us.
Old Aug 29, 2001 | 09:36 PM
_Charles_'s Avatar
formerly 'RiceRocket'
Oxygen is required for fuel to be burnt in an engine. This is usually supplied by taking in air from the atmosphere. However the air that surrounds us also contains a large quantity of nitrogen. The high temperatures found within the engine cause nitrogen to react with any unused oxygen to form nitrogen oxides [NOx].
Exhaust Gas Recirculation or EGR procedure takes some of the exhaust gases back into the intake of the engine. These gases have already been used by the engine and no longer contain very much oxygen. By mixing the exhaust gases with fresh air the amount of oxygen entering the engine is reduced. Since there is less oxygen to react with fewer nitrogen oxides are formed. This can greatly reduce the amount of nitrogen oxides that a vehicle releases into the atmosphere.
Nitrous Oxides produce pollution.
I knew that automotive book would come in handy.
Charles
My Blog: www.HotRodCaddy.com
Old Aug 29, 2001 | 10:01 PM
Epicman's Avatar
Me angry, you cry
Well then I guess that sorta makes sense...maybe.:confused:
Old Aug 30, 2001 | 06:51 PM
Alan's Avatar
drives euro trash
Something is wrong with Fords EGR setup on the Zetec motors. The EGR opens up too quickly under partial throttle (i.e. normal driving) and causes severe stumbling/studdering/hesitation. The cure is a small vacuum reducer which makes the EGR open up slower under partial throttle. This was the best money I have spent on my car so far.
Another cure would be to remove it all together which I plan on doing eventually.
Old Aug 31, 2001 | 05:58 AM
stangerang's Avatar
whoopdy fucking do!
yeah all EGR systems suck--they seem to be one of the first things that will go wrong on alot of cars...and doesnt it seem like it would be un healthy for your engine??? just think of all the carbons going back into your intake getting it all messy and dirty.....
200 points away from a 300
Old Sep 4, 2001 | 12:29 AM
rb70383's Avatar
Manic Mechanic
If it works right an EGR when removed might not increase performance. It depends on the system. On another note if the valve goes bad it will put excessive exhaust in and causing the stumblingsurging etc that was stated and can also cause light throttle pinging. On some cars you have to fool the computer that it still works if you take it off. Had this problem with a friends Neon when he did a engine swap. He used a block off plate for the egr but left the lines connected. The computer would throw a code for EGR system. I had to decifer the service manual and interesting enough all he had to do was leave the line open to atomsphere. Last I heard he hasnt popped an EGR code again. They also came on the mid to late 70s Chryslers.:barf:
