Recommendations for a Headerliner installer
Old Apr 24, 2008 | 07:12 AM
ZDriver96's Avatar
Default Recommendations for a Headerliner installer
Looking to have new head liner put in my camaro. Any recommendations on good shops or people for this job?
Thanks
96 M6 Arctic White Z28
"SLOW LT1"
Blue 2005 Acura TSX
Old Apr 24, 2008 | 10:31 AM
RX007CYM's Avatar
Lucky
Are you thinking custom or aftermarket or just want an OEM replacement? The headliners I have done were simply pull the seatbelt plastics and some other misc things off. Jam a screw driver between the current headliner and the roof and pull it out. Then take your replacement and snap it in, along with the other things that you removed. I have never done a GM car so perhaps they are different. Good luck!
Originally Posted by JustMiata
It's like this: The toadstool juice fires through the unicorn injector into the fairy dust chamber, where the tiny wizard does his secret work...Then a gang of keebler elves get hopped up on the crystalline byproduct of the wizard's tinkering, (they smoke it) and then the elves push the spinning triangle through a series of dimensional portals to a final realm codenamed the "exhaust port..." At least that's my undersanding of rotary sorcery...
Old Apr 24, 2008 | 12:27 PM
ZDriver96's Avatar
I want as close to original as possible. same color, same look everything.. If the headliner is made by someone else and meets oem quality thats fine
"SLOW LT1"
Blue 2005 Acura TSX
Old Apr 24, 2008 | 03:48 PM
steve's Avatar
madpom
Capri Auto Interiors - About Us
matt owns the joint give them a call
i really suggest you stop by and see the work that comes out of that place
Old Apr 24, 2008 | 07:15 PM
Mars_302's Avatar
Race Photographer
you need yours redone or a whole new one?
