Jay Leno test drives the Tesla Roadster
Old Jul 9, 2007 | 08:10 PM
shinmei2006's Avatar
Default Jay Leno test drives the Tesla Roadster
Tesla Roadster review | New Car Reviews - Times Online
It’s also built a car that weighs 2,600lb, which is a few pounds heavier than the standard Lotus, whereas most electric cars would be hundreds of pounds heavier. And it handles and drives, for all intents and purposes, like a real sports car.
The difference with this is that it’s faster than a standard Lotus. For something to succeed it has to not only do it as well but better.
Driving the car takes some getting used to. But boy is it quick. It does 0-60mph in 4sec. Like a petrol car, you just put your foot down and go. The real trick with electricity is that it’s alive. You put it in a box and it either escapes or dies. The best way to use power is at the point of generation, which is what hybrids do but then you are back with the problem of having two powerplants and the extra weight. Electricity is the best way to run an automobile in the sense that there is no maintenance of any kind.
http://www.hashiriya.net
Old Jul 10, 2007 | 05:22 AM
RX007CYM's Avatar
Lucky
Great article. Rep4u
Originally Posted by JustMiata
It's like this: The toadstool juice fires through the unicorn injector into the fairy dust chamber, where the tiny wizard does his secret work...Then a gang of keebler elves get hopped up on the crystalline byproduct of the wizard's tinkering, (they smoke it) and then the elves push the spinning triangle through a series of dimensional portals to a final realm codenamed the "exhaust port..." At least that's my undersanding of rotary sorcery...
Old Jul 10, 2007 | 05:47 AM
SleepingB18's Avatar
just mike.
no maint. of any kind? are you sure? cause on electric forklifts, we would have to at least change the motor brushes, cause they would wear down after a while..
Old Jul 10, 2007 | 06:34 AM
aaron1017's Avatar
is not Rotarded anymore!
Perhaps its a brushless motor? I am looking around on http://www.teslamotors.com but its going really slow at the moment.
LS1/T56 Heads Cam 1994 FD
Old Jul 10, 2007 | 07:18 AM
just mike.
Without proper efficiency, a motor will convert electrical energy into heat instead of rotational energy. <-- that clears it up...
Old Jul 10, 2007 | 07:38 AM
Puto's Avatar
El Puto ©
It's a maintenance free battery.
Old Jul 10, 2007 | 08:17 AM
thereturnofdark's Avatar
Obama made me Republican
those rims looks like beefed up GSR blades.
Old Jul 10, 2007 | 08:46 AM
just mike.
+1 minus 1 blade
Old Jul 10, 2007 | 12:08 PM
more like falken hanabis
