Best way to clean engine bay
Old Jan 28, 2007 | 11:04 AM
Whaazup17's Avatar
Default Best way to clean engine bay
ok.. I need to clean my engine bay. Can I clean it with simple green and water? and then just air dry everything off with an air hose?
Also, what about the battery terminals?
Whaazup17's Avatar
a wire brush and what kind of chemicals for the battery terminals?
Old Jan 28, 2007 | 11:15 AM
P057's Avatar
isuck
batt terminals you just mix a glass of water and a few tablespoons of baking soda until it turns rather cloudy, just pour a little on top of the terminals, should start bubbling it away, then pour some more after its bubbled a lot to keep washing it away, repeat as necessary until clean.
Old Jan 28, 2007 | 11:17 AM
P057's Avatar
isuck
Get degreaser specially made for car engine bays and read the instructions. Try not to cheap out and get something environmentally friendly. Make sure to try to cover the alternator and battery as best as you can with plastic bags or something. If it does get wet, dont worry about it, just dry it off with a towel and maybe a hairdryer or something and dont turn on the car for a while.
good luck and have fun, i want to do this again someday soon too.
Old Jan 28, 2007 | 11:32 AM
Whaazup17's Avatar
I was told you were supposed to do this while the car was running.. but then I got to thinking why would you want to wet a piece of metal that is hot....
Am i right?
Old Jan 28, 2007 | 11:34 AM
88RedRex's Avatar
Protected Taurus .45/.410
you can pour regular soda(coke) on the terminals and make sure you cover your distributor(sp) also when cleaninh you want want moisture or water under the cap the car will run like shit
New sig. coming soon
Code 52 VTAK On A Switch
MCOR Automotive LLC
http://www.mcorautomotive.com/
PM MCOR for any electronics, upholstrey, accessories or window tint (813) 362-5454
They will take care of you as they did me
88RedRex's Avatar
yes the car should be off
MCOR Automotive LLC
Old Jan 28, 2007 | 11:35 AM
zedron's Avatar
Engine De greaser and a hose is what I use. Then air dry with or without a air hose. I dont even cover anything up with a bag to protect it. I just don't drive my car for a while and try to avoid the electrical. Works great.
And I second the idea on not to get the environment friendly stuff as it is not nearly as strong.
Good Luck
B20 Non-Vtec Turbo: 275whp/234wtq @ 8 psi 2/10/2007
LS/Vtec Turbo: ???whp/???wtq @ ? psi (Secret )
Tuned by John Vega @ Phearable.net
Old Jan 28, 2007 | 11:44 AM
88RedRex's Avatar
yea see if you were to cover everything you would be able to drive your car right after but hay thats the way you do then thats cool not everybody is the same, i cleaned my engine bay once and didnt cover the distributor and my car ran like shit, i had 2 get a new one
MCOR Automotive LLC
Old Jan 28, 2007 | 11:57 AM
Whaazup17's Avatar
uh ohh I just did it but didn't cover my distributor.. but I covered everything else... but I aired the distributor off good though..
