Ahh Help
Old Jun 30, 2006 | 06:53 PM
Ringo_'s Avatar
Default Ahh Help
ok so my car wont even go in reverse the shifter just stops, it dosent even start to go it just dosent move....but it gets in all other 5 gears fine...tranny? clutch? what you think
Old Jun 30, 2006 | 06:55 PM
mrnicejetta's Avatar
farfromügen
Double check the shift linkage. You might be able to adjust it. Either that or the reverse synchro is completely shot, and if you force it in it would just grind. Has it been gradually getting more difficult to hit reverse, or just all of a sudden?
Der schnellste mann im langsamsten auto
Old Jun 30, 2006 | 07:16 PM
Ringo_'s Avatar
just all of a sudden...and i forced it in just enogh to back out of my parking spot and it grinded and sliped back into netural
Old Jun 30, 2006 | 07:39 PM
farfromügen
You'll probably have to crawl underneath and adjust the linkage. I don't know what you have so I couldn't tell you all the steps involved. But for a VW you just put it in a gear, release the bolt(s), turn/slide the linkage, and tighten it back down. It may take a couple of times to it perfect. It usually helps to have an extra set of hands to keep the shift lever in place.
Old Jun 30, 2006 | 08:20 PM
Ringo_'s Avatar
96 prelude
Old Jun 30, 2006 | 10:05 PM
Troux's Avatar
Try adjusting your CMC freeplay adjustment rod on the clutch medal. If your disengagement point is too low, the clutch might not be fully disengaging.
Old Jul 1, 2006 | 07:31 AM
Temporarily, to "clear" the shifter,
Put it in low, let clutch briefly out.
That will make it easier to go into reverse.
Others have offered some good solutions, too.-Bob
Old Jul 1, 2006 | 08:36 AM
farfromügen
If that was it wouldn't it cause difficulties in all gears? I thought it was just reverse?
Old Jul 1, 2006 | 10:24 AM
Troux's Avatar
It would cause the most difficulty in the lowest gears.
