key won't turn.......please help
Originally Posted by lifeisviewtiful
here's a list of what i did so far:
tried the key jiggle and repeatedly turning the wheel
tried putting wd-40 on the key and in the cylinder
tried using the shift lock override to shift the car in nuetral and repeatedly step 1.
tried pushing in the pin(that releases the cylinder) with alot of force to see if it will break free
got desperate and tried to use a good ole fashion flat head screw driver.
Originally Posted by WhiteFwdsm
This happened to my brother. Ended up being the battery. But this was in his Nissan Sentra. Everytime the key got locked in the ignition and wouldn't come out was because his battery was weak or terminals were loose. Thats the only thing I know maybe thats what it is.
at this point i am going to get a drill and a solid drill bit and just drill carfully through the pin all together, destroying it, which will alow me to get the cylinder out........
I got here (too late) to tell you that I can fix it. If you need further help,
leave me a message.-Bob 813-839-4281
Paleease
I can't even begin to tell you how many late 80's early 90's camry's I have jumped in at auctions and bid sales and not been able to turn the key. Seriously, they're the only one that sticks out in my mind because it happens half the time I try to drive one.
I can't even begin to tell you how many late 80's early 90's camry's I have jumped in at auctions and bid sales and not been able to turn the key. Seriously, they're the only one that sticks out in my mind because it happens half the time I try to drive one.Good friend of mine has a 91 Camry...turns the key to start it then pulls it out
Also, graphite is the magical stuff you are supposed to use for locks...dunno why, but it definetly works well. Spray some in all of your locks like once a year.
ASE: Brakes
ASE: Brakes
