03 wrx need help!stuck in safe mode!
Old Jun 21, 2006 | 05:29 PM
COBRA2DAMAX's Avatar
The Man!
Default 03 wrx need help!stuck in safe mode!
My buddie pulled the negative battery terminal off of his 03 wrx to reset the computer because the car was low on coolant and the check engine light was on. He filled up the coolant tank and reconected the battery. Now the car runs like shit on top in in boost. It is running way to rich. Is the computer stuck in safe mode? If so how can he correct this to get the car out of safe mode. It ran fine before the battery was disconected. Any help is much appreciated. Does he need to pull the main fuse from the computer to reset the damn thing? I'm a ford guy so i'm not firmilar with Subaru's. Thanks all!
Old Jun 21, 2006 | 07:49 PM
ShiZor9's Avatar
I give out Dutch Ovens!!!
Autozone can check and clear check engine codes for your buddy's WRX so this doesnt happen again...
Old Jun 21, 2006 | 11:36 PM
+1 on Autozone-Bob
Old Jun 21, 2006 | 11:49 PM
mrnicejetta's Avatar
farfromügen
Or any place with an OBDII scanner: Advance Auto Parts, Auto Zone, Pep Boys... Just go to whoever is closer to you, but I'd call them first because for some reason their scanners like to grow legs and wander off. Also tell them what kind of car it is because there are different OBD ports and the adapters like to grow legs as well.
Der schnellste mann im langsamsten auto
Old Jun 22, 2006 | 01:50 PM
BlackWind's Avatar
Requiem
sounds like you need a new ecm.
okay
Old Jun 22, 2006 | 02:01 PM
singlecamvteccrxsi's Avatar
bitch you crazy
yo
Old Jul 9, 2006 | 11:02 AM
The Man!
Default Wrx is fix'd!!
It was an exhaust gasket! The damn thing was loosing boost on top end and making the car run horrible. It's fix'd now. Thank you all for your help.
