A turbo gasket I can't seem to find
Old Apr 17, 2006 | 03:27 PM
Figs's Avatar
Default A turbo gasket I can't seem to find
I bought a Airesearch T3 Turbo from someone on here. The turbo exhaust housing to the downpipe is a 7 bolt instead of the 5 bolt or 3 bolt. I have the flange for the custom downpipe I'll be needing but I still can't find the gasket that would go between the turbo and this 7 bolt flange/downpipe. Which vehicles came with this 7 bolt? All I found online was the gasket for 5 bolts and 3 bolts. Help please!
Old Apr 17, 2006 | 04:53 PM
Figs's Avatar
Originally Posted by John
you don't really need a gasket so long as the flange is true. I've never used one, never had a problem either
Cool cool, wasn't sure if I could really do that since every turbo application I used was with a gasket between the turbo and downpipe. Thank you for the info!
Old Apr 17, 2006 | 05:05 PM
qitstrn's Avatar
Can you spot me 20 cars?
+1
Old Apr 17, 2006 | 05:16 PM
vertigo_16201's Avatar
I never ran gaskets, but i had an exhaust leak on my last setup cuz the flange warped under heat. The flange was 3/8" tho.
Old Apr 17, 2006 | 06:34 PM
limegreenneon's Avatar
John Its me chris aka corn !...how everbody just make sure its true...If its ont true, Just find somebody with a bridgeport, and get it milled.......IF you have no luck on finding anybody with a bridgeport....WE have one at work
Old Apr 18, 2006 | 12:40 PM
Figs's Avatar
Originally Posted by Just Dave
I just put a bit of ultra copper RTV and I never had a bit of trouble.
Hmmm, never heard of doing that.
Thanks everyone for all the help.
Old Apr 18, 2006 | 06:20 PM
Orion ZyGarian's Avatar
7M 2JZ bird in pear tree
Ultra copper is usable as a gasket material for damn near anything on a car except for intake seals and turbo related stuff...you can use it for exhaust stuff like O2 sensors, but the footprint itself I think gets too much heat from the turbo to last.
You may be able to get away with it, but Permatex says it is only good up to 700*F. If you cant get a precut gasket, then its worth a shot
ASE: Brakes
