nopi pro rwd outlaw and drag radial class has something new this year
so if some of u remember i posted on here how nopi is going to let the 10.5 outlaw boys run.well its is true and it is going to happen the 10.5 big dawgs are going to take the crown from the nopi boys this year.heres the rule.
8 Cylinder:
Small Block Motors:
Nitrous (480ci max) 2200 lbs.
Roots Supercharged (480ci max) 2700 lbs.
Centrifugal Supercharged (480ci max) Gas only 2800 lbs.
Turbocharged (370ci max) 8.2 Deck only
Twin 76mm/single 94mm max 2400 lbs.
Turbocharged (480ci max)
Twin 88mm/single 106mm max 2700 lbs.
Big Block Motors: 530ci Max
Nitrous: Gas Only 2500 lbs
Roots Supercharged: Alcohol 2700 lbs.
Centrifugal Supercharged: Gas 2700 lbs.
Turbocharged: Gas 2700 lbs.
Deduct 100 lbs. for converters.
Max turbo size is defined by inlet opening and inducer wheel size measurements.
no carbs either witch sucks
on another post it said v-8s can only run a 10.5 tire but i see nothing about it on the rule page so that means some of the 10.5 guys might be switching to a larger tire so i will say now some of the 10.5 guys on a full size slick will hit 6.70s forsure.
and the will be letting 93 and up cars run in the drag radial class but u will have to be fuel injected to.i think they are scared of what the carb guys got going on.
8 Cylinder:
Small Block Motors:
I'm really wondering how long it will be before they increase the weight. I just don't see them letting these guys run cars that are this light.
Interesting point of the 10.5 guys here locally i'm not sure how many of them could get the car down to these weights. Alot of them will have to figure out what they want to lighten to get as light as they can.
