guide to buying rims?
Old Dec 9, 2005 | 06:53 PM
BlzSity's Avatar
Default guide to buying rims?
Maybe somebody can answer some pretty basic questions on buying rims. Does the brand of rims really matter, does it fluctuate much on quality. Or should i stick with a known brand (rota,enkei) Should i buy the set alltogether with the tires? the lighter=better? Sorry if this sounds dumb, but i just don't want to screw anything up and regret the rims i get. I want 17' black ones like the slipstreams. size 205 on my tires for my 200sx.
Old Dec 9, 2005 | 07:48 PM
Chris C.'s Avatar
I ♣ Baby Seals.
There are many different ways to form a wheel, and each way will affect the characteristics of the wheel. It is all up to the purpose you will be using the wheel's for. Remember, Lighter wheels=less inertia. This in turn reduces the amount of energy to accelerate, stop, and turn. You must also think about width too. You need to make sure you are not in danger of hitting your struts or coilovers, if any. The use of spacers may be needed.
Take Casting for example. Gravity Casting is mainly used for looks, when whieght is not an issue at hand. Aluminum is poured into a mold and is left to gravity to hold it in. These rims will weigh more in relation to their strength.
Then you have Low/High pressure Casting that will apply a varied amoutn of pressure to the mold in hopes of achieving a denser, stronger wheel.
The last casting method is is the spun rim design. It is a process of heating the inital mold, and then spinning and shapeing the "rim" with rollers and other machinery. I think BBS uses this process for their rims...
Aftermarket companies, much like the one's you mentioned will produce forged wheels. These are used by most aftermarket companies because of the strength to weight ratio achieved from the process. Semi-Solid Forging is where aluminum (or a special alloy in higher priced wheels) is technically melted and shoved into a mold at high rates. Common Forging is where a solid peice of billet aluminum is forced into the forging dies under extreme pressure, creating the ultimate in dense/ strong wheels.
Then to make things even more confusing for ya, there are Multi-Peice wheels that incorporate different methods for various parts on the wheel.
J-Linewheels uses a forging and spinning process to create 2 and 3-peice wheels...
Hope that helps.
/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\/\- Probably my best post ever.
Old Dec 9, 2005 | 08:18 PM
JonLGT's Avatar
Just for decoration
Hope that helps.
Did you write a report on this or somthing?
Old Dec 9, 2005 | 08:24 PM
Chris C.'s Avatar
I ♣ Baby Seals.
Haha, I don't know what came over me! I think I know more about rims than I do the engine...Wow. I guess I looking for rims a little too much lately...
Old Dec 9, 2005 | 08:29 PM
JonLGT's Avatar
Just for decoration
I <3 Those ghetto chromies... when are you replacing them?
Old Dec 9, 2005 | 09:33 PM
Chris C.'s Avatar
I ♣ Baby Seals.
I'm picking up a set of black powdercoated SE whesls tommorow....
Old Dec 10, 2005 | 09:09 PM
siboe's Avatar
SCHEMING & PLOTING
i think i learned more in ur report on rims then i did all year in intro to humanities...lol
by the way i like the blingers it adds character
Old Dec 11, 2005 | 06:42 AM
Chris C.'s Avatar
I ♣ Baby Seals.
Then you should get a 5-lug bolt adapter and buy them for your car....
