Help!
Old Sep 22, 2005 | 05:29 PM
m0nk3y's Avatar
pwns.
Default Help!
Car (02 hyundai elantra) hesitates when starting and cranks really slow, gradually getting faster till it starts, and sometimes will dim headlights and make my radar detector go nuts (like power on/off a few times a second)
thoughts?
Originally Posted by Lil Ze
Florida is the new Miami through and through.
Old Sep 22, 2005 | 05:31 PM
95gainfla's Avatar
smokes weed...everyday.
battery is low/alternator is bad/starter is bad/its a hyundai
I <3 RooR!!!!!!
Old Sep 22, 2005 | 05:35 PM
m0nk3y's Avatar
pwns.
that was helpful
im sure its one of the first three, just trying to narrow it down...
Old Sep 23, 2005 | 06:04 AM
m0nk3y's Avatar
pwns.
up
Old Sep 23, 2005 | 06:13 AM
B18C5-EG's Avatar
Originally Posted by 95gainfla
alternator is bad
+1, Dose it only do it when it starts up, and is ok after you have it running for a bit and drive it? or dose it keep doing it.
Old Sep 23, 2005 | 06:36 AM
m0nk3y's Avatar
pwns.
it starts up slow, and every now and again at idle (sitting in a parking spot, at a traffic light in drive, etc...) the lights will dim, RPMs will drop slightly, and radar detector will go nuts.
Old Sep 23, 2005 | 06:42 AM
B18C5-EG's Avatar
Sounds like the symptoms my friend had it turned out being a bad alternator. Hope thats all.
Old Sep 23, 2005 | 06:48 AM
m0nk3y's Avatar
pwns.
me too... thanks!
one other note:
the car has been sitting for a few days. this only happens when its been sitting for more than 2-3 days.
I have to drive to georgia today and im trying to figure out of it'll be ok for the trip, since it only gives me problems after sitting and at idle. thoughts?
Old Sep 23, 2005 | 07:01 AM
95gainfla's Avatar
check to make sure your ground wire is on nice and tight.
I <3 RooR!!!!!!
Old Sep 23, 2005 | 09:06 PM
Jordan Y.'s Avatar
15 seconds EXHILARATION
How old is your battery? Batteries can go out as soon as two years after you buy them depending on your driving habits and what kind of battery you buy. That would be the first thing I suspect if it's more than two years old. Check the terminals for corrosion and while you're at it make sure the connections are tight- a loose ground or loose positive will cause problems. If you have access to a multimeter read the voltage across the terminals, if it's below 12 volts there is a problem; the battery is not holding charge or it isn't getting a charge from the alternator. Turn the car on and read the voltage again, if it reads above 13.5 volts your alternator is probably still fine and it's probably the battery. That this problem crops up mostly after the car hasn't been run for a few days further supports the bad battery theory. A bad battery or loose connection can cause random problems at lights when the alternator isn't putting out much juice- especially if your idle drops too low. My sister's car would lose stereo power, the lights would dim, and the AC would cut out all randomly at lights- it turned out the simple fix was tightening a loose wing nut on the positive battery terminal.
