where to get a steering column....?
Old Oct 22, 2004 | 05:04 PM
aimisgoop's Avatar
Cracka-Faced Cracka!
Default where to get a steering column....?
last nite someone broke out my window and jacked my system, busted up my steering column trying to jack my truck...ripped the whole thing appart(ignition is in 10 peices)...i have a $500 deductable...where do i go.
AIM: AIMisGOOP
Originally Posted by moldyhands
in the immortal words of the very wise Kid Rock, "3 foot tall with a 10 foot dick"
though for me, you'd have to change it to 10 inches, and you'd have to change inches to millimeters, and you'd have to change 10 to 5 and you'd have to change dick to poor excuse for one.
Old Oct 22, 2004 | 05:08 PM
93ex's Avatar
Just Ledoux it!
GCC
I would say junkyard or stealership
Old Oct 23, 2004 | 11:19 AM
aimisgoop's Avatar
here
AIM: AIMisGOOP
Old Oct 23, 2004 | 11:20 AM
aimisgoop's Avatar
now that i am a little less pissed and can think more clearly...its not a steering column...im not sure what that would be called....? ignition i guess?
AIM: AIMisGOOP
Old Oct 23, 2004 | 04:50 PM
0HP930's Avatar
Guest
You will likely want to get the plastic pieces for the column replaced so it doesn't look like crap. Your option there is either junk yard or dealer for those.
As far as the ignition goes you should be able to get a new switch from either a dealer or auto parts store.
My recommendation if you want to use the same key for all the locks on the car is to take your original key and the new lock to a qualified locksmith so they can set all the tumblers to match the original key.
Old Oct 23, 2004 | 07:05 PM
0HP930's Avatar
Guest
Did you miss the part where he said that he has a $500 deductable?
Old Oct 24, 2004 | 05:28 AM
0HP930's Avatar
Guest
Then you should realize that his goal is to do this as cheaply as possible so he can minimise his losses.
Old Oct 24, 2004 | 04:18 PM
aimisgoop's Avatar
exactly...im already taking a raping due to the fact Direct General Insurance Co. does NOT cover "aftermarket stereo's".
AIM: AIMisGOOP
