What to Use to remove high Temp Paint???
Old Apr 7, 2004 | 05:29 PM
REDchirp's Avatar
Blown 7thgen... Literally
Angry What to Use to remove high Temp Paint???
I just bought a muffler that has Black High-temp paint on certain parts of the muffler that i don't want on there... i want the original polished up look from what came from the factory... what have you guys used to remove High-Temp Paint??? thanks!!! this is very much appreciated!!!!
~Derek
Old Apr 8, 2004 | 05:11 AM
Young,Fablous,&Broke's Avatar
oven cleaner or paint remover. I dont know what affect that will have on the Steel, though.
Old Apr 8, 2004 | 06:58 AM
TheShow50h's Avatar
The little 5.0 that could
I would probably try paint thinner or acetone ... if that didn't work I'd just wet sand with some fine grit paper and repolish the affected areas.
-Vince
Old Apr 8, 2004 | 08:39 AM
REDchirp's Avatar
yea.. the paint thinner did absolutely nothing to it... it's still in full effect on it... is it hard to wet-sand? never done it before... and what is required... I also heard that Carb. Cleaner will take it off definitely, heard that it has worked on other peoples mufflers before... but wasn't sure if anybody else had experience with using carb cleaner before i go out and buy a bottle of it... thanks!!!
Old Apr 8, 2004 | 08:41 AM
TheShow50h's Avatar
Carb cleaner is strong as well and might do the trick ... wet sand is just a piece of sand paper and water that you smoothly rub over the areas you want to be bare.
Wetsanding paper is always black, and I'd use around 800-1000 grit paper and a $3 small tub of aluminum polish.
-Vince
Old Apr 8, 2004 | 09:01 AM
REDchirp's Avatar
Thanks Show50h! I'll try that!
and Mars_302... where can I purchase aircraft paint stripper? and how much? and will it screw up the stainless steel of the muffler? thanks!!!
Old Apr 8, 2004 | 07:57 PM
REDchirp's Avatar
Airplane Paint Stripper works like a fucking charm!!! i sprayed it on and the paint was falling off in minutes... and it doesn't damage the metal at all... i also bought a polisher as well.. and polished the stainless steel up after taking the paint off... made it shine like a mirror!!! I LOVE IT!!!
