What is the highest flowing cat?
Old Dec 8, 2003 | 07:38 PM
ZDriver96's Avatar
Default What is the highest flowing cat?
I found a 3rd party test showing Carsound, FLP, both stock cats, and TTS cats tested against eachother.
FLP flowed 5 cfms more than the carsound but i know they are about twice as much.. Those too were much better then the rest.
Now i saw claims that Random Tech Cats flowed 40 cfms under Carsounds.
But i did not find anything on Catco cats other than that they flow good. How good i dont know?
Right now I can pick up carsound cats for 30 bucks each 3inch in and out.
Any links to tests on cats?
96 M6 Arctic White Z28
"SLOW LT1"
Blue 2005 Acura TSX
Old Dec 8, 2003 | 08:01 PM
ZDriver96's Avatar
i know this but my car is loud as fuck. and after 45 minutes i get out of the car and smell like gas
"SLOW LT1"
Blue 2005 Acura TSX
Old Dec 8, 2003 | 09:54 PM
Whaazup17's Avatar
non at all man non at all
Old Dec 9, 2003 | 06:14 AM
lstepnio's Avatar
1337 H4x0r
A couple of tricks to address the noise and smell issues you describe. First, look into installing a resinator and make sure the tip of the exhaust exists past your bumper cover.
-luke [www.majjix.com]
Old Dec 9, 2003 | 06:30 AM
ZDriver96's Avatar
Hmmm i guess we arent speaking the same language here... I think what Im trying to ask is "What cat flows the best?".... ?????
I already did some research and found some cats that will support my power output without sacrificing horsepower.
tips are past the bumper... i like my tips... not changing them...
"SLOW LT1"
Blue 2005 Acura TSX
Old Dec 9, 2003 | 10:22 AM
ZDriver96's Avatar
check this out .... http://www.installuniversity.com/in...on11.122001.htm
Each pair of catalytic converters restrict about eight ( rear wheel horsepower on stock LS1’s. David Vizard’s research shows that 2.2 cfm of flow at 20.4” of H2O will support 1 horsepower. 2.2 cfm is the optimum flow through the exhaust system and reflects open pipe flow. Assuming that the average LS1 puts 300 horse power to the ground, that is a 2.67% increase in power.
So for a stock LS1 that puts 300 to the ground and still has both cats but on a 2.5 inch y pipe.. An 8 rwhp increase happens when the cats are removed...
HP= Flow (cfm)/2.2 cfm 567.8 cfm/2.2 = 258.1 horses..
This means that the stock cats can support up to 258.1 horses...
("looks" like study was done in 1999)
So if i want two carsound cats they will flow 372/7 each x2= 755.4cfms
745.4/2.2 = 372.7 hp 2.5 inlet/outlet carsound cats can support..
I wonder if 28 inch H20 flow tests were for 3inch cats.. im not sure..
If thats the case then 2 3inch carsound cats can support 436 rwhp without losing any power at all...
Sounds good too me...
"SLOW LT1"
Blue 2005 Acura TSX
