Big Problems need Help!!
Old Jan 8, 2006 | 10:28 AM
CobraCommander's Avatar
Default Big Problems need Help!!
I have a 95 Cobra and here is the problem I am having:
When I can start it it fires and runs lean for about 30 seconds if I hold it at around 2500 then I can watch the a/f's go stoich then dead rich after about 45 seconds then around a min it dies.
Codes I pulled are:511,539,564,565 cleaned the iac,o2's,tb,tps is .99 and responsive to position without holes,maf has been verified with another one(new) killing me
Old Jan 8, 2006 | 11:49 AM
evocrazy1's Avatar
did you check the codes to book?, you could have a bad computer
ASKED TO BE BANNED
Old Jan 8, 2006 | 01:37 PM
primetime1267's Avatar
Smacking Her A$$
I came across this info for ya.
I hope this helps...
511 O Read Only Memory (ROM) test failure
539 O A/C on/Defrost on during KOEO
564 O
(Cars ONLY): Electro Drive Fan circuit fault
565 O Canister purge solenoid circuit fault
Info gathered here: http://www.iequus.com/assets/manuals/3143e.pdf#search='1995%20ford%20computer%20codes'
Independent AMSOIL Dealer
XPSYNTHETICS.com
Sarasota, FL ZO#1863313
Old Jan 8, 2006 | 01:40 PM
$hawn's Avatar
lives in a glass house
If the canister purge goes bad ^565 in a sn/95 it reeks havoc on the a/f.
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Jan 8, 2006 | 02:07 PM
evocrazy1's Avatar
Bad memory, an a bad canister purge soleniod will cause those problems
ASKED TO BE BANNED
