FS: TONS OF 99+ MUSTANG PARTS (vortech, tank, clutch, +more)
2v 4.6L Stock Block
-I have the stock 2-valve I pulled out of my 02 GT. It ran fine and has 53k on the clock. Does not include the accesories. (A/C pump, Alternater, ect).
Price: $500.
VORTECH V-2 SC-TRIM SUPERCHARGER
-Upgraded to a new Unit. im including the brackets, fittings, and oil lines. the bracket is for a 2v 4.6. I can also include a vortech mini race blowoff valve.
Fits engines up to 680 horsepower
Maximum airflow: 1,000 CFM
Maximum boost pressure: 20 PSI
Absolute maximum impeller speed: 53,000 RPM
Adiabatic efficiency: 75%
Available with straight or curved discharge
Part numbers below do not include drive pulley
8.75" Wide, 9.44" Tall, 5.52" Deep (not including input shaft)
Price: $2800
42lb FRRP Injectors
-great condition
Price: $180
Spec Stage III clutch (422miles)
-clutch is like brand new. motor came with a new clutch.
Price: $275
04 Cobra Tank/Pumps
-tank has low miles. going with a sump setup from a 99stang.
-comes with the Hat assembly
-pumps are BRAND NEW
Price: $500
Price: $500.
Price: $2800
42lb FRRP Injectors
-great condition
Price: $180
Price: $275
04 Cobra Tank/Pumps
Price: $500
Adam
05 BMW 745LI
05 BMW 325I
94 Mustang V6 (ls1 Powered)
93 Mustang Notch (ls1 turbo project)
Adam
05 BMW 745LI
05 BMW 325I
Where you located. Im interested in the motor. Was this motor forced induction?
Any intake on this motor?
i had my v2 setup on the block running 8lbs. i just got a built motor so i can run 22lbs.
Adam
05 BMW 745LI
05 BMW 325I
Adam
05 BMW 745LI
05 BMW 325I
Where you located? Do you have teh stock intake anymore?
Good price on the motor but you are 165 miles and almost 3 hours away from me. I might try to find something a little closer. Thanks anyway.
