question on offset steering rack bushings
Old Feb 13, 2012 | 12:28 PM
blacksheep-1's Avatar
Default question on offset steering rack bushings
I personally don't think very much of them, however I have them for my Granatelli crossmember in my 93 FOX. One of the first things I noticed was that the rack bushings really don't index on anything, they just hang out on their own. I was thinking that might be OK for an drag racer but they don't look too solid for an autocross or roadrace car. Secondly, the crossmember is not dead nuts square and the aluminum rack bushings seem to be placing undue stress on the rack itself. for this reason I'm thinking of going back to delrin or stiff rubber stock type rack bushings and using a bumpsteer kit to solve the issue with the spindles.
Any input?
Old Feb 13, 2012 | 12:44 PM
Na306StAnG's Avatar
Flowmaster nut swinger
They do sell solid aluminum rack bushings.
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Feb 13, 2012 | 02:03 PM
GNs-r-slow's Avatar
Bondsman
Id get rid of the Granatelli K member personally if youre looking for quality
Old Feb 13, 2012 | 02:30 PM
They are aluminum
currently the budget only allows for MM knockoffs.
Old Feb 13, 2012 | 02:56 PM
Na306StAnG's Avatar
And they still move? Hmmmm
Largo fl 33773
MV#72427
Old Feb 13, 2012 | 03:15 PM
I didn't say they moved, I said they look like they would move. The cams (spacers, whatever) fit into the rack and are rotated so the rack is at the highest point. But there is nothing to keep then there, I would have thought there might be some sort of dowel or something to keep the rack indexed at the top. I may even drill a hole in the K-member bracket and drive a roll pin in. The issue I have is that if you bank it off of the elephant turds the tracks use to line the corners with, it could cause the rack to move.
Old Feb 14, 2012 | 05:55 PM
Stangonline's Avatar
That's how the bushings are. I have a real MM K- member and aluminum rack bushings and it seems like the rack would move but it doesn't.
Still no excuse for using an MM knockoff
Let me know when you want to buy the real deal - I'm an MM dealer
Jeff
93 Coupe - check out my blog - http://www.93coupe.com
01 Cobra - Stockified - Wife Owned and operated
68 Coupe PROJECT <- Been in the family for 25 years!
Old Feb 14, 2012 | 07:50 PM
Fair enough
I didn't know that until after I bought it about 6 months ago. I knew I didn't want a UPR, the Granatelli looked pretty beefy. I know MM and Griggs (and maybe Agent 47) are the gold standard.
Old Feb 15, 2012 | 06:43 AM
mustangman98's Avatar
Mullet Powered
Team Z K-member...Now where near as much as the overpriced MM stuff and this stuff is GREAT!
Team Z Motorsports - Suspension Kits and Components for hardcore Mustangs & more!
03 Gt - SOLD!
88 LX Coupe - 308 with a few mods...
Old Feb 15, 2012 | 06:24 PM
^^I dig TZ for drag racing but for corner carvers it's hard to beat MM.
Jeff
