major problems, need help
Old Oct 14, 2010 | 06:14 AM
Superwes98's Avatar
Default major problems, need help
ok my friend has a 91 lx vert that was swapped over to 5speed way back when he still lived in maryland. (just to put that out there so u know his car was running all this time with a A9P computer.) then it wouldnt start with his computer so he had to put my friends 90 computer in. we put his back in when we puttin different relays in and it still wouldnt start.
anyway his car ran GREAT and then his clutch went out. he changed the clutch and went to start, and nothing. then we found out he didnt have the the tranny plugged in for it to start (i dont know wat the plug is called). then he started it right up and drove it for about an hour or so and then his fuel pump relay started ticking and gettin hot. once it got so hot the car would just die and he would have to wait for it to cool down to drive it again.
after a while the driving time before it would shut off got shorter and shorter.
he ended up replacing the fuel pump relay about 3 times thinkin that was the problem but it wasnt.
so last night we ripped it all apart to check and see if any wires were shorting out. but come to find out that the EEC relay under the hood was ticking with the fuel pump relay.
couldnt find any problems with the wires but when we would jiggle some the ticking would get worse SOMETIMES. but we checked those wires again and they were fine.
so we swapped relays and his worked fine in my car, he then had new relays in the car and i still was ticking.
so if anyone has ANY IDEA please help
P.S. - We changed the relays with perfectly good ones (MINE) and it didnt make a difference. so thats not the problem.
Old Oct 14, 2010 | 07:26 AM
DrDirt's Avatar
Team Geritol Racing
Try changing the computer again. They are 20 some years old now and sometimes the little blue capacitors inside will leak electrolytes and cause problems. I had to replace all three in mine because they had leaked and corroded one leg completely thru. If things work with a known working computer, that may be your problem. The caps are cheap, $1-2 each and some careful cleanup and soldering will fix the problem. Of course, he could have done some welding on the car and completely fried the computer too.
YO! Barry! You LOST!
Old Oct 14, 2010 | 11:19 AM
DrDirt's Avatar
Team Geritol Racing
Here's a "how to" and a "why" on the capacitor problem I was talking about.
A9x ECM's (and same years ECM's) Failures Due to Age
Old Oct 14, 2010 | 01:03 PM
9050LX's Avatar
I had a Dodge magnum V-6 (1995)used to do something similar,would chatter the relay when cold and would run fine when warm out.Good advice here....
Old Oct 14, 2010 | 02:41 PM
Superwes98's Avatar
well this one is doin the opposite lol
and drdirt- i know wat your talkin about i had to do that to mine before. and he didnt do any welding, just changed his clutch
Old Oct 15, 2010 | 04:46 AM
Superwes98's Avatar
checked both computers and nothing is wrong with them
Old Oct 15, 2010 | 06:24 AM
DrDirt's Avatar
Team Geritol Racing
The EEC powers up the FP relay at switch on. Maybe there's a problem with the ignition switch...the one burried under everything on the botom of the steering column, not the one you stick your key into. The Ford ignitions of that era are known to go bad like a Muslim in a hand RPG factory. Did you check out the EEC relay? Check the ground for the EEC in the kick panel and by the battery?
Old Oct 15, 2010 | 03:21 PM
Superwes98's Avatar
thanks will do
Old Oct 16, 2010 | 11:13 AM
Superwes98's Avatar
can someone call or text whenever u get a chance. we r workin on it today again
813 407 3363 Wes
or 443 938 4633 Bobby- owner of the car
