Where to get egr delete kit/plate....
Old May 19, 2010 | 07:54 PM
10InchesSoft's Avatar
Default Where to get egr delete kit/plate....
I was installing my throttle body and the bottom bolt on my egr cracked off and now its sucking in air and not sealing, where can I get the kit to eliminate it?
Old May 19, 2010 | 08:11 PM
Miles.'s Avatar
Previously 19-camaro-88
This is what I have on my coupe, except 75mm
Steeda Autosports 555-3107 - Steeda Autosports EGR Eliminator Brackets - Overview - SummitRacing.com
-Miles.
Old May 20, 2010 | 03:15 AM
So that piece attaches to the throttle body and u bolt the egr to that?
Old May 20, 2010 | 08:16 AM
SVT1996Cobra's Avatar
What?
to eliminate the EGR using the stock(type) spacer and the not the plate above you will need these:
Mustang EGR delete plate eliminator 87 - 93 5.0 : eBay Motors (item 120569842609 end time May-24-10 06:23:32 PDT)
87-95 FORD MUSTANG 5.0 EGR ELIMINATOR SIMULATOR: eBay Motors (item 300428725422 end time May-24-10 14:44:25 PDT)
Old May 20, 2010 | 10:43 AM
Miles.'s Avatar
No, That piece eliminates the EGR. It goes between the throttle body and the intake and your throttle cable bolts to the eliminator plate. Unless you have a Cobra intake then this piece is irrelevant to you.
-Miles.
