Head / cam question
Old Jul 18, 2009 | 04:52 AM
StangItMan's Avatar
Question Head / cam question
Can I successfully use the E303 cam with the stock GT40P head, and can I use 1.7 rockers?
BTW - will the Explorer intake add value (hp) to the mix?
The '87 Coupe to be built and raced in our son's memory.
Cameron Lee Koss - 9.1.1991 - 8.05.2011
I can do great things when not experiencing "Man-A-Pause" StangItMan '08
Old Jul 18, 2009 | 05:54 AM
500HPLX's Avatar
What springs are you using? That is to much lift for the stock GT40P springs to handle. Get the Ford Racing spring upgrade at the least (M-6513-A50).
I used GT40P heads, a Comp Cam XE264HR with .512 lift and 1.6 rockers on a bone stock '88 302 shortblock. I was able to reuse my stock 302 push rods, but the block has not been decked and the heads were new also. I orginally had a Cobra intake, 65mm TB and a fender well cold air kit on it. It was still Speed Density and it ran great. That combo gets good mpg, has great drivability and runs strong for what it is.
I got my heads on line from Tri State Cylinder heads. They dont have new castings for the P heads anymore, but they still sell the same package with used castings.
GT40P heads, w/ 1.94 I, 1.54 E, .550 lift dual spring package, with decent seat presures for this cam range.
No matter what anyone tells you they have done, YOU will need to mock up you combp and measure it.
Dont take the risk and throw away your money!
Old Jul 18, 2009 | 06:14 AM
StangItMan's Avatar
I have an Explorer upper/lower and GT40p heads I was going to sell and was now considering using this stuff. Maybe just the heads on the HO block (carbed) and still selling the intake.
Valve spring tip (FR) good with total .528 lift (using Crane 1.7's)?
Thanks
Old Jul 18, 2009 | 07:46 AM
500HPLX's Avatar
Should be fun with a 150 shot on it!
Old Jul 18, 2009 | 12:27 PM
racingrick's Avatar
POTENTIALLY FAST
the intake is actually a good improvement over stock, similiar to a cobra/gt40.
from what i understand they all have very similiar flow characteristics.
a friend went 11.05 with an explorer intake, TFS heads, and a 150 shot.
Old Jul 18, 2009 | 02:45 PM
500HPLX's Avatar
See,
FUN!
That is why we do it!
