Nos question.
Old Feb 5, 2009 | 02:40 PM
Big Chris's Avatar
tampa car scene
Default Nos question.
I have a bolt on 89 and just installed a nx wet kit with a 125 shot. I got a set of plugs that are one autolite platinum a26 and was told the higher the number the colder the plugs, do you guys think I should go to autolite platinum a27 as these are tne next set colder? And my timing is set at 14 degrees, with the 6al should I go to 10 degrees or to something even lower?
Old schooler.
Old Feb 5, 2009 | 03:46 PM
bvh's Avatar
bvh
1 range colder should be fine. and rule of thumb for timing is 2* for ever 50 hp of shot so 10* should be fine
Old Feb 5, 2009 | 03:53 PM
racingrick's Avatar
POTENTIALLY FAST
what bvh said
+make sure fuel system is up to par.
Old Feb 5, 2009 | 04:15 PM
91Notch's Avatar
Is workin on his car
I am not a very big fan of platinum plugs for a nitrous use.
Keep your plug gap around .035 also. But with having the 6al its not that critical you close the gap, it should be able to handle it.
Old Feb 5, 2009 | 05:25 PM
Tiffiny's Avatar
I can fix your bullshit
I too hate the platinum plugs.I blame the parts stores they push them like crack....
Old Feb 5, 2009 | 05:54 PM
95coBraSVT's Avatar
banana republic
Platinum plugs with 4 electrodes and a squiggly center are da best mang!
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Feb 6, 2009 | 07:32 AM
Big Chris's Avatar
tampa car scene
Ok thanks guys, I will return the plugs and get non platinum.
Old schooler.
Old Feb 6, 2009 | 08:53 PM
Tiffiny's Avatar
your a smart guy
Old Feb 7, 2009 | 04:26 AM
barry bledsoe's Avatar
The lost pony
get a regular autolite plug and the number should be lower not higher,and you definatly do not want a plug with extra electrods,its extra metal to heat up causing detonation easier,regular autolite plugs worked for me for years with a 125 first stage and a 250 secondand 375 third
Old Feb 7, 2009 | 08:46 PM
hasa68mustang's Avatar
For Autolite plugs the higher the number the hotter the plug. With NGK plugs the higher the number the colder the plug. I am running autolite 24's on my 95 stang with a 150 wet shot. I am on my 7th bottle now with a stock bottom end, stock head, stock cam, pretty much intake/headers/exhaust and a diy tune... lol
Holley 2300 500cfm direct mounted to a D8 head
durapark ignition, JP performance Timing chain
IHI turbo, 10 psi, K&N! video of it "in action"
http://videos.streetfire.net/player....D-7B3C2B51D66F
