Fuel Injected gurus come in
Old Sep 30, 2008 | 04:41 AM
  #21 (permalink)
DrDirt's Avatar
Team Geritol Racing
Check your PM's Brian
YO! Barry! You LOST!
Old Sep 30, 2008 | 05:02 AM
  #22 (permalink)
DrDirt's Avatar
Team Geritol Racing
Originally Posted by GNs-r-slow
EDIT~~~~
Founds this issue.... Ran the car wiothout the little timing spout in at the track. He set the timing back to run on the motorwhen he got home, shut the car off reinstalled timing spout and car would not start. Like it had no fire. Pull the spout out car will fire right up. Any ideas, Tried different A9L same thing. Module , distributor (pick up) issue?
What did he set the timing to when the spout was out? The EEC expects it to be set at 10* BTDC, a few degrees either way won't make that much difference but the EEC calculates the timing assuming that the base is 10* and then ads the amount that is necessary to achieve the timing in the tables depending on load, rpm, ECT and ACT. When you pull the spout, it locks the timing at whatever you physically set it to. If he set it to say 20* at the track, as long as that spout is out, it will be running 20* at all loads and RPM's. If he put the spout back in then the EEC will be adding an extra 10* everywhere because it thinks the base is 10* when it is actually 20*. It could be pulling or adding too much timing and doesn't want to start.
Old Sep 30, 2008 | 07:14 AM
  #23 (permalink)
EsCoRtLvR's Avatar
Escort Connoisseur
On the original question have you guys put a noid light on the suspected bank to see if it's toggling the injectors properly?
Shooting at the wind here but maybe it's a harness connection issue on one bank with those crappy "salt&pepper shaker" connectors. I always use a pick to spread the male ends out a little by pushing on the center of the male pins, add some dielectric grease and reconnect, they can be a bugger to get back together though after you spread the male pins .
"Genuine" ASE certified Mazda, Hyundai, Isuzu Technician
Escort Enthusiast Site
Automotive Electrical Specialist, Tuning Specialist
Old Sep 30, 2008 | 07:58 AM
  #24 (permalink)
GNs-r-slow's Avatar
Bondsman
WE RAN CAR AT TRACK NO SPOUT...YES I KNOW IT LOCKS TIMING THATS WHY IT WAS RUN W/O
NEXT...AT HOME PUT TIMING BACK TO RUN ON MOTOR.... SHUT CAR OFF INSTALLED SPOUT...TRY TO START.... NO START....PULL SPOUT CAR START GOOD...PUT SPOUT IN....NO START
I WASNT ASKING HOW TO SET THE TIMING
Old Sep 30, 2008 | 11:12 AM
  #25 (permalink)
DrDirt's Avatar
Team Geritol Racing
To tell ya the truth, it was hard to tell what you were asking.
OK, good luck.
Old Sep 30, 2008 | 01:59 PM
  #26 (permalink)
EsCoRtLvR's Avatar
Escort Connoisseur
Maybe the SPOUT is bad and has too much resistance in it ? Just a thought, try putting a jumper wire there in place of it.
The 3rd post on here has a nice little common issue checklist of no start but cranks stuff...
Click Here
Old Sep 30, 2008 | 07:24 PM
  #27 (permalink)
GNs-r-slow's Avatar
Bondsman
Click Here
Thanks for the link
Old Oct 1, 2008 | 12:34 AM
  #28 (permalink)
GNs-r-slow's Avatar
Bondsman
OK, good luck.
Sorry Dr D we keep caps on for all entries at work, wasnt screamin at ya
Old Oct 1, 2008 | 05:14 AM
  #29 (permalink)
DrDirt's Avatar
Team Geritol Racing
OK, yer off the hook.
And yeah, try a jumper wire in place of the spout. I've had one die on me.
Old Oct 1, 2008 | 07:32 AM
  #30 (permalink)
DrDirt's Avatar
Team Geritol Racing
Another off the wall thing you might check is the harmonic balancer. If it's still the stock one, the rubber might have deteriorated and let it slip enough that when he reset the timing at home it's nowhere near what he thinks it is. Not likely but hey, the damn thing won't start.
