High Idle
Old Jun 20, 2008 | 01:52 PM
Newguy07's Avatar
Default High Idle
My 5.0 mustang (1987) has a high idel (around 1500rpm) Anybody know what could be the cause of this?
Everything else works fine.
Interested in investing? Let me know and I will help you get started.
http://friends.zecco.com/r/55c661e4107a102cae57
Originally Posted by XtremeVision
Haha, I really dont care, its just Newguy gets under my skin like you wouldnt believe.
Hes so fucking annoying..him and tackelberry should have kids together. Jesus.
Old Jun 20, 2008 | 02:20 PM
91Notch's Avatar
Is workin on his car
vacuum leak??? IAC faulty??? timing is off???
The list goes on.
Old Jun 20, 2008 | 03:37 PM
Hurstmeister's Avatar
Gunk clogging the throttle body blade not letting it close all the way,.. tons of reasons.
If nothing has changed,..
Check the spring on the throttle body to make sure its returning all the way. Manually open and close it to make sure its returning. If still not right from there I would check for vacume leaks.
If you still have many of the original vacume lines,.. you gotta figure a 21 year old car,..those rubber hoses are well past their intended service life. On my girls 87 I replaced almost every single vacume hose on the car after we got it. Most were gummed up so bad that they would collapse on themselves. The ones that werent like a gummy bear were dry rotted.
In most cases the car will run a lot better with new vac lines. 87 cars used air density,.. so most of the EFI parameters are governed by vacume. Check the vac line to the MAP sensor. Its a pain in the ass because it runs from under the upper intake. If it feels squishy and soft,.. replace it.
Hurst
Old Jun 20, 2008 | 05:42 PM
herrcomestrouble's Avatar
Try cleaning the IAC with some carb/throttle body cleaner.... does it surge?
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Old Jun 20, 2008 | 07:04 PM
limegreenneon's Avatar
PM sent
Old Jun 21, 2008 | 10:07 PM
Mars_302's Avatar
Race Photographer
wth have you been?
Old Jun 22, 2008 | 09:39 AM
MiDiablo's Avatar
Originally Posted by Mars_302
wth have you been?
+1
Old Jun 22, 2008 | 07:03 PM
wth have you been?
backpacking in Europe...
