nitrous install on my 92 gt
Old Jul 9, 2001 | 01:01 PM
stangerang's Avatar
whoopdy fucking do!
you want to put the nozzle in your intake duct if you put it in right at your throttle body it might not spread to all of the cylinders correctly.--------you pretty much have to put it in your back seat floor--you have a hatch right??---you should retard your timing 2deg for every 50hp over 75hp-- so if you run a 100 only 2-4deg probably only 2deg will do. pressure could depend on what all you have done and youll probably have to play with it for a while before you find the best pressure. -with a 100 shot you should run colder plugs the regular(heat range) ones will last for a while but not forever. on 100hp jets you should see at least 85hp to the rear wheels if less something is wrong.. i think NOS says their kits are within 5% of advertised horsepower but youll have to find that out for yourself. ---------- try posting this in forced induction also--maybe there will be more people there to give you advice..?
200 points away from a 300
