Sticking throttle body
Old Jan 13, 2008 | 08:40 AM
**CHRIS**'s Avatar
Called the amba lamps
Default Sticking throttle body
Is there a better way to fix this issue? I've been cleaning my BBK throttle body with throttle body cleaner then use WD-40 after...it fixes this for about 5 days before the shit is sticking again....
The car is so much more fun to drive when I can press on the accelerator and go...smoothly. When it's sticking, I give a ton of pressure and the pedal doesn't move until it breaks free and then goes like 1/2 throttle. It's a pain in the ass.
Is there a better spray lubricator than WD-40? Something that lasts longer maybe?
Old Jan 13, 2008 | 10:33 AM
98svtcobra's Avatar
John
pull it out an clean it would work best
N/A all the way
Old Jan 13, 2008 | 10:54 AM
Newguy07's Avatar
Yes there is better sprays then wd-40.. There is tri-flow I always like to use. It has teflon in it.
Old Jan 13, 2008 | 11:31 AM
**CHRIS**'s Avatar
Thanks...I'll look for some of that.
Old Jan 13, 2008 | 01:19 PM
BigDawg's Avatar
has his prioritys ef'd up
I would disassemble it, and remove the blade and possibly take soe steel wool to it.
Ryan
1990 Mustang GT (In Process)
1993 LX Coupe (Daily Driver, but just choose not to)
2005 Excursion (Big Pig)
Old Jan 13, 2008 | 01:35 PM
bottlefed93's Avatar
I had one that started sticking and found that it was worn out and the blade was moving around alot causing it to bind up. But thankfully Raymond (riverviewnative) hooked me up with one, give him a shout if you can't get it fixed. There was no helping mine.
Every time I cross one thing off of my TO DO list,I add two more!!!
Old Jan 13, 2008 | 01:39 PM
**CHRIS**'s Avatar
It's weird, after I clean it, it works fine. But after a week of driving, there is alot of carbon buildup on it. The car runs rich for the spray and since I don't spray everytime I drive it it's possibly just getting overloaded.
Somebody else told me that BBK's need to be cleaned often but once a week is ridiculous.
Old Jan 13, 2008 | 01:45 PM
Mars_302's Avatar
Race Photographer
turn the idle screw a little, it gets passed the stuck spot, chances are its worn a little on the shaft
Old Jan 13, 2008 | 04:20 PM
Just Dave's Avatar
Do It In The Dirt
Mars, do you encounter this issue alot on GM cars by any chance? The TB on my S10 sticks pretty bad at times, and another guy I know with a Tahoe has the same issue.
29 Hard and Single
My Rail Buggy
Old Jan 13, 2008 | 04:32 PM
Mars_302's Avatar
Race Photographer
Its been done a few cars at the shop, usually do this after giving is a very thorough cleaning with some carb clean, a brush and a rag
