"pumping" out ATF?
Old Sep 18, 2007 | 07:19 PM
quicksig's Avatar
Default "pumping" out ATF?
I was planning on changing the trans fluid/filter in the interceptor tomorrow and had read previously somewhere you could detach the "in" line to the trans cooler, start the car, and cycle through the gears to pump the entire system dry of ATF - just shut the car off as soon as the flow lessens or it spits a bit.
Read a friends Hayne's manual and it just suggests dropping the pan, swapping the filter/gasket, and replacing the 4-5 qts you drained that way.
Seeing as there's 12 qts in there total I like my method a bit more - I'm not going to cause the trans any harm by draining it this way am I? Just want to make sure before I start...
Thanks
Brian
'03 Cobra Convertible - for sale - pulley, cai, 442rwhp
Millenium Yellow '02 Z06 - intake, cam, lt's & full exhaust
Old Sep 18, 2007 | 07:31 PM
SmokinS13SR20's Avatar
That ginger...
I would not suggest it...
Running a tranny with little to no fluid = a no-no in my book.
Come to Harbor Freight and buy a Transmission Fluid Exchanger.
Old Sep 18, 2007 | 07:32 PM
Tiffiny's Avatar
I can fix your bullshit
Dont Do It
Old Sep 18, 2007 | 07:33 PM
Mars_302's Avatar
Race Photographer
I wouldnt put in gear, it pumps fluid while in park. you can do it that way. A lot of fords do have a drain plug on the torque converter. Doing the filter/draining the pan, then draining the converter pretty much gets rid of all the fluid in the tranny
just look for a rubber plug on the trans bell housing, pull it out, then rotate the crank till you a plug, its like an 11mm. most of them have this, not all
Old Sep 18, 2007 | 07:41 PM
topher469's Avatar
BillionClub Member BISHES
I wouldn't do it man!! Not a good plan, it will work but it will also heat shit up and may damage it.
Originally Posted by DrDirt
You also make a foolhardy leap of faith in assuming that the government can execute a program properly when they can't even execute terrorists properly!!!
Old Sep 18, 2007 | 07:43 PM
Scott's Avatar
You can thank me later...
The Penzoil oil change place near me here in Brandon has a machine that will do this. I had it done on my moms GT and my Crown Vic a few years ago. Worked great. Cost like $50 or something. My guess is all Penzoil lube places have them.
9.31 @ 148.12 ( Drag radials, street driven, low boost, no fancy race car shit....
___________________________________________
TR's Official In House Realtor
PM or E-mail Me If you are Looking To Buy/Sell/Rent A Home.
Special TR Bonus For Using My Services.
Old Sep 19, 2007 | 09:10 AM
DrDirt's Avatar
Team Geritol Racing
That sounds like the old school way we used to it in the 60's...except you don't run it dry, you stick the "in" line in a supply of new ATF and the "out" line into a sufficiently large empty container. You run it until it starts pumping nice clean red fluid from the "out" line. Pretty much not worth the effort and the wasted extra ATF if you ask me.
YO! Barry! You LOST!
Old Sep 19, 2007 | 11:24 AM
DEATH ZEPPELIN's Avatar
previously SLOWBOOST
+1. beat me to it.
SUCH IS THE RULE OF HONOUR.
Old Sep 20, 2007 | 10:59 AM
quicksig's Avatar
Thanks for the advice - looking back it really would not have been worth it. Got about 10.5 of the 12 qts out just draining the converter and dropping the pan. Swap made a world of difference in how the car shifts however - much quicker and smoother...
Brian
