Squeaking when I turn right??
Old Aug 22, 2007 | 07:50 PM
ShakinIt's Avatar
The sig nazi's bitch...
Default Squeaking when I turn right??
Ok, the car is making some kind of squeak/squeal when I turn right at low speeds. It sounds almost like break squeal, but it does it when I'm not using the brakes. And it doesn't make the sound when I turn left either....thoughts?
2011 Mustang GT 5.0 Premium, 6M, Brembos, nav and HIDs
Flowmaster catbacks, K&N drop in, for now!
Old Aug 22, 2007 | 08:23 PM
jokers institute's Avatar
needs a rich uncle
maybe a bent comtrol arm? is you tire rubbing?
hey its ok the more parts that fall off the lighter i get
Old Aug 22, 2007 | 11:51 PM
flynbrian's Avatar
Loud Noises
Smile axle bearing
Could be a axle bearing taking a dump, when you turn right it loads that axle, and that could be why you hear the sqeaking, if it's going bad, they usually start cutting a groove into the axle, i'd pull the wheel off and check it, it's possible it could be the brakes also, if the pads are worn, either way, if you pull the wheel, you ought to be able to trace it down. Good Luck,
Old Aug 23, 2007 | 06:35 AM
Ford DNA's Avatar
As Seen On TV!
Mouse under your left hip.
Amanda
"People know me."
"Be kinder than necessary, for everyone you meet is fighting some kind of battle."
Old Aug 23, 2007 | 12:49 PM
on_ice's Avatar
Mine does this too, let us know what you find.
Old Aug 23, 2007 | 02:36 PM
ShakinIt's Avatar
I think that's it....
Old Aug 23, 2007 | 02:50 PM
Shamus O'Toole's Avatar
Redneck Yatchclub member
don't turn left....................................
Old Aug 23, 2007 | 02:59 PM
harleys's Avatar
lol.
2008 Ford F150 - Work Truck
1991 XJ - 5.5" lift
Old Aug 23, 2007 | 03:36 PM
**CHRIS**'s Avatar
Called the amba lamps
You don't have to be touching the brake pedal for your brakes to squeal..
Could be that metal warning layer.....
Old Aug 23, 2007 | 05:51 PM
ShakinIt's Avatar
yea, but it only makes this sound at low speeds when turning right; no sound going straight or left; wouldn't the break squeal all the time? I think the axle bearing theory sounds good; I'll check it this weekend
