Quarter window removal
Old Aug 22, 2007 | 04:30 PM
Subzero's Avatar
Thread Napper
Default Quarter window removal
Gonna remove quarter windows when I paint, Are they glued? How do I go about it,and will I be able to save the mouldings which are in perfect shape atm.
Old Aug 22, 2007 | 06:33 PM
n8secstangg's Avatar
you have to pull your inner 1/4 panels out and there are a bunch of 11/32 nuts inside that hold teh windows in...once u get them ALL out, if you miss even one u will break the 1/4 window, then take a heat gun and heat the butyl tape up and slowly push the windows from the inside out, make sure you get all teh nuts, there are some that are hard to find
chad
www.racinginnovationsfl.com
www.xsrcylinderheads.com
4.842@156 and 7.53@192 on radials
Old Aug 22, 2007 | 06:34 PM
fakesnake's Avatar
pull the back seat...remove theheadliner trim...pull the inside plastic
panels...take out the window mounting nuts...comes right out...btw...the rubber molding around the windows is an integral part of the window...gl
