An actual tech question...WOW
Old Apr 17, 2007 | 04:41 PM
Stangonline's Avatar
Default An actual tech question...WOW
There's this car that I know of that has low compression in 1 cylinder. I did a leakdown test on it and sure enough, it was dropping about 30% of the air. As I raised the PSI though, all of a sudden, it sealed up and held all of the pressure. Sticky valve is what first came to mind, but I wonder if a damaged ring could act like that?
Old Apr 17, 2007 | 04:50 PM
$hawn's Avatar
lives in a glass house
i would think it would be a valve problem unless the air pressure moved the piston passed some damage in the cylinder.
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Apr 17, 2007 | 05:20 PM
Na, we did it 5-6 times, each time the exact same thing. I doubt I was lucky enough to get the piston in the same spot each time. Also had it in gear with parking brake on.
Jeff
93 Coupe - check out my blog - http://www.93coupe.com
01 Cobra - Stockified - Wife Owned and operated
68 Coupe PROJECT <- Been in the family for 25 years!
Old Apr 17, 2007 | 06:30 PM
Mars_302's Avatar
Race Photographer
probably a ring to be honest.
Old Apr 17, 2007 | 06:35 PM
topher469's Avatar
BillionClub Member BISHES
Very possible!! But I would still go with the valves first. but if your that far apart might as well pull the other head do them all and re-ring the bottom end. You know red-neck rebuild if your broke!!!
Old Apr 17, 2007 | 07:48 PM
broke 5oh's Avatar
Redneck it if your not wanting to keep it too long!!
Old Apr 17, 2007 | 08:45 PM
shinysideup's Avatar
TR Balla Donor Supreme
valve, repair appropriately.
Old Apr 18, 2007 | 02:14 AM
69Boss521's Avatar
PORK CHOP SAMICHES!!!!!
Oil could be spashing it and sealing it up??? I know when I check cylinder I squirt some oil in there to see if it makes a difference in compression. If it does the rings need to be replaced.
Derp!
Old Apr 18, 2007 | 02:25 AM
OldMan's Avatar
Donut Killer
Oh fudge.....
SC Motorsports
11801 State Road 52
Hudson, FL 34669-3092
(727) 856-8768
FordSpeed Racing
11733 66th St., Unit 123
Largo, FL 33773
(727) 549-8255
Dynojet Chassis Dyno
Old Apr 18, 2007 | 06:57 AM
Originally Posted by OldMan
Oh fudge.....
Jeff
