Help putting 302 together
Old Feb 11, 2007 | 10:52 AM
Whaazup17's Avatar
Default Help putting 302 together
Ok... I had to take one head off but did not take the valves springs out and also took off the intake manifold.. I changed gaskets and everything
Now the problem is I can't get it running.
The motor has fuel
I turned the #1 piston to TDC and reseted the timing.
What else should I try? I'm stuck..
Old Feb 11, 2007 | 11:13 AM
shinysideup's Avatar
TR Balla Donor Supreme
could be that its TDC on the exhaust stroke. pull the distributor and reset so that the rotor is 180 degrees out. if thats not it, you can put it back just as easy.
Old Feb 11, 2007 | 11:38 AM
Whaazup17's Avatar
I did it with the piston all the way up? Is that now how it is done on these 302 motors?
Old Feb 11, 2007 | 11:40 AM
topher469's Avatar
BillionClub Member BISHES
yes but it is a 4 stroke engine!! So you have to make sure you are on an intake stroke not exhaust.. The cam shaft does move when the crank does thats why he said make sure its not 180 out.
