Radio ?
Old Oct 21, 2006 | 11:46 AM
Na306StAnG's Avatar
Flowmaster nut swinger
Default Radio ?
Anyone ever have a problem with fox mustang stereo setup sounding like shit??
I have a brand new Pioneer head unit and 6 Polk audio speakers in it and I'm really not happy with the way it sounds.
Some one told me to wire all my speakers with my own wire not to use the factory wiring or should i just get an amp to run all my speakers???
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Oct 21, 2006 | 01:23 PM
allibabba's Avatar
I had a car with an Alpine head unit and Polk speakers with the factory speaker wires. It sounded like crap too. Could be something to the factory speaker wires?
"Congressmen who willfuly take actions during wartime that damage morale and undermine the military are saboteurs and should be arrested, exiled or hanged".
President Abraham Lincoln
Old Oct 21, 2006 | 01:38 PM
tony122's Avatar
mine is alpine head unit i ran all the wires with kenwood speakers,it sounds prety good,you have to get speakers that operate in the rms watt range,that you head unit sends out per chanel,if you get speakers that need more power to run then u gona have to use a amplifier,if you got polk most likely you gona need to run a amp,check the back of the speaker and see how many rms does it operate from,i think averge head unit is like 50 watts per channel so the rms would probably be from 15 to 18 rms watts per channel,go to crutchfield.com it tells you their how that shiznit work,or i can do it for ya...
Old Oct 21, 2006 | 01:49 PM
Steve B's Avatar
brings his heater.
my eclipse head with 5 volt pre amps sounds great through the amps and my wires.
dump your stock wires and definately run your own
Old Oct 21, 2006 | 01:53 PM
ODB's Avatar
ODB
S.Y.L.O.
amp all the speakers.
Old Oct 21, 2006 | 02:43 PM
86stang's Avatar
You do get a noticeable difference when your speakers are connected to an amplifier...however I just put a pioneer headunit and speakers (nothing special at all) with some audiobahn speaker wire and just by being connected to the headunit... a couple hundred dollar speaker system - sounds good for what it is. Sony amp for two soundstream 10's
Old Oct 21, 2006 | 04:38 PM
Na306StAnG's Avatar
I'm gonna have to agree with you! Your the fifth person with pretty much the same setup and same out come.
Largo fl 33773
MV#72427
Old Oct 21, 2006 | 04:49 PM
Na306StAnG's Avatar
Your radio sounds really clear and gave me the idea that something was wrong with my wiring. Till you found the amp then i was thinking of adding one. but for now i thing i'm just going to re-wire it
Largo fl 33773
MV#72427
Old Oct 21, 2006 | 07:10 PM
Sumthin Nuu's Avatar
Unsettling your debt
Even a small inexpensive amp makes a nice upgrade instead of wiring the speakers straight to the head unit. Always run your own wires, its cheap and worth the effort every time.
Old Oct 22, 2006 | 12:30 PM
bottlefedLX's Avatar
Don't be so angry
If there is a factory amp behind the factory radio, you can unplug it, and that should solve your problem.
John
John
1992 Mustang LX 5.0-Powerdyne BD-11A, 3.73's, FRPP clutch, chrome Ponies, Mac headers, Aeromotive regulator, MSD 6A, MSD BTM, FRPP 42# injectors, Pro-Flow Air Optimizer, Trick Flow Track Heat intake, Edelbrock 75MM TB, AFM Power Pipe
