Transmission knocking PLEASE PLEASE HELP!!!
Old Aug 11, 2006 | 08:20 PM
Slow5ho's Avatar
Default Transmission knocking PLEASE PLEASE HELP!!!
i have a 1969 c4 in my fox it has started this knocking noise very very very load irratic knock. i sounds as if you were hitting the bell with a hammer. the nosie will go away if you take the car just off idle to around 1200 rpm i took the tranny off put the bell back on the motor and started it no noise. i took of the flex plate no cracks all bolts tight i took the tranny apart a thust washer was lose i replaced the noise went away. now the pesky noise is back. i agaijn took the tranny out no loose washer i took apart the tranny anyway replaced all the washers put tranny back in and this time no solution i still have a knock. please please help me i have run out of ideas.
thanks Paul.
if you would like to hear i will be at bmp with the car sat. i plan to run it anyway as there are no issues with the car other than noise. maybe it will let lose and i will find the problem.
Old Aug 12, 2006 | 06:08 AM
Na306StAnG's Avatar
Flowmaster nut swinger
Originally Posted by Slow5ho
I plan to run it anyway as there are no issues with the car other than noise. maybe it will let lose and i will find the problem.
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Aug 12, 2006 | 06:18 AM
bigjim2.5's Avatar
loose torque converter bolts
Old Aug 13, 2006 | 10:03 AM
dragula's Avatar
Motherfuckin Trend Killer
Have you aligned the bellhousing?
Thats right fools, 2 Prostockers this year
Old Aug 13, 2006 | 12:57 PM
Slow5ho's Avatar
no cats, all converter and flywheel bolts tight trans is in alignment with motor and diveshaft. sprayed the car knock gone again for now.
Old Aug 13, 2006 | 01:09 PM
dragula's Avatar
What kinda convertor? size-stall?
Old Aug 13, 2006 | 04:22 PM
Na306StAnG's Avatar
Largo fl 33773
MV#72427
Old Aug 13, 2006 | 06:05 PM
Slow5ho's Avatar
i am not sure of the make but it is a 5000 nitrous conv. it is very very tight. it will only flash about 2000 rpms off idle but it will go up to 5000 on the brake.
Old Aug 14, 2006 | 02:38 PM
Na306StAnG's Avatar
It really sounds like something in the stall.
Largo fl 33773
MV#72427
